Home Made Injection And Electronic Dizzy, Whats It Off?
Deleted
Edited by Sbox
After much waiting my KE30 2 door arrived, it came with some bits that were unusual. Someone had modified some center point injection and a electronic dizzy to fit the 5k. All the wiring was there as well as an ecu and they guy I bought it off said it was running before he bought it. The 5k engine is definitely in need of a rebuild as number one piston has the edge burnt away and number 4 bore is badly scored (wonder if the injection played a part, or whether it died a natural death). Can anyone identify the injection, dizzy and ecu?
That is very interesting!!! Is it easy to open up the ecu? As I have seen a few with the manufacturer written on the printed circuit board ie: toyota, nissan etc!
Hi,
Interesting find I will say.
As for the fuel injection it could be off a ford I was going ot do this a while ago but project was stopped so see if ecu as brand names etc on it might give clues.
As for dizzy. Doesn't look home made it looks like a 7K-E dizzy.
The newer vans that have K motors with EFI have a dizzy the ECU can vary etc so they run better and they look like the one you have. My local wrecker had one once I was tempted with getting it for my boosted K project But I was unsure of how much I could retard id with the ECU. But he was asking $120 for it so that is probably what it is worth.
But all in all nice find. Go get 7K EFI gear for $200 at a wrecker and do it all Toyota again as most of the loom well similar wires will be there and hey EFI 5K :P
Cameron
Edited by camerondownunder88
SHIT hey sorry about that I just also noticed the tang missing to drive the pump..This might be why the 5K died...LOL
As dizzy then any numbers on it markings also home made machined stuff you can usually tell if it is DIY from lathe marks etc so more detailed shots. Also The old Bosch kit to make a hall effect setup on holden fits a K motor dizzy I tried it with a spare setup I had. So if it is home made could be a DIY housing running a kit like those bosch ones. So can we get internal pics etc?
Cameron
Deleted
Edited by Sbox
definitely EA Falcon TPI. don't know why they bothered with it to be honest cos it was a totally shit system. As for the ECU, how can you seriously tell from the outside without a part number? Apart from the pin connector shape, they are all pretty much a silver box!
Hey all
That doesn't appear to be falcon TBI, as i have just finished putting this on a 3k with megasquirt, that looks more like a delco system off an unleaded JD Camira (the leaded ones were MPI)
These can be quite a flexible and programmable system with the right software, looks like the dizzy has been modified nicely too.
Heres a pic of falcon TBI on 3k in my ke30- (excuse the temporary throttle hookup)
Deleted
Edited by Sbox
Deleted
Edited by Sbox
Deleted
Edited by Sbox
