Takeing 4k-c Head Off
ok i need help ive taken the rocker cove or and the head studs from the left and righ but tthe head will still not come off i need urgent help was p[lanning on doing it all tonight email me or add me or answer here [email protected]
cheers bayden
  • Replies 38
  • Views 8.9k
Pre Planning Prevents Piss Poor Performance.
Dude, why do you not have a Gregorys for it?
If the head bolt's are out, and the manifolds are off, there are three screwdriver holes at the base of the head. Use those holes, a screwdriver and lever the head off.
You may have to pull the therrmostat housing off the front as well, i can't remember. It's been a while.
PS: I flatly refuse to email someone with an address of sik_vl ........
so the manifolds have to come of ? grr. i was young ! wen i got that adress I'm not some hot head don't judge a guy buy hes email mate
Pull both manifolds off.
Take tappet cover.
Remove head bolts.
Hit with rubber mallet to crack the gasket.
tappet cover ? it move up and down about 5ml alreardy that without the manifolds of the gasket was no probs to crack open just lifted the head.
Yes , but the fingers still have to physically type it.... :y:
Torque settings are also in the FAQ as well I think.......
Edited by Redwarf
thabks mate bigg help. my head like on my shoulders was confused been thinkin bout it for ages thay not all that had to get off ? will i need new gasket wen putting them back on ? ?
ps iits just a pig and before it only reved to 4500 will that change now heads fixed ? and will a longer exaust help that its only ver short pasenger door with muffler ?
cheers
ctrl c cttrl v hahah its k
Probably. Normal operating procedure dictates that you should. If you've been REALLY careful taking them off, you might just be able to goo them up and go. But it is better to change it.
I don't do technology, anybody around here will confirm that! Shortcuts are out. It's all I can do to even make the letters appear on the screen.......
ok just went down shed how can ig get to them i can't get to them all crowded can't get spaner nor ratchets on to them grr this is going to be baithchy job ill doi it tommorow
i got mine of with a universal bit with ratchet and long extension :y:
a socket set with a 100mm extension bar should do the job on the manifolds...can get to the bolts directly if you go straight at them. i've taken mine on and off about 3 times in the last 2 weeks ;)
Not to go against what everyone has said you can get it off with the manifolds on if done right. But really when the head comes off pointless keeping manifolds on as A you should install new gaskets there. You might need them again, and they can get in the way. Quick run down.
Pull off tappet cover.
Undo all LINES for vac, fuel etc to manifolds head, spark leads, exhaust pipe etc.
Undo All cylinder head bolts.
Undo front thermostat housing
now tap with mallet should come off. If it is in the car still crank the car over compression will pop it off. If you do that I like to just keep 4 head bolts slightly in still so it wont blow it sky high.
Cameron
