December 29, 200718 yr comment_217114 Hey Guys and girls, I'm new on this forum but i have been a member of SRC (sydney rolla club) for awhile now, i drive a ae82 but just got given a KE55.. i have some good plans for this car including a full restore of the body and respray and also tidy the interior up... but my big question is the engine that I'm wanting to put in it.... i have 2 choices.... a CA18DET or a 4AG(T)E...... I'm not after massive power or anything like that just some nice boost action lol.. i need help on which engine is the easiet to fit... and i also need to know what modification needs to be done to run either of those engines... i have done some research, and if I'm correct if i run te CA18DET i will need to modify the tunnel to allow for the gearbox am i right??? and on the 4age i need to swap to a w series box??? but where I'm having the most trouble is the diff and running gear.. i have NO clue what to run, and what brakes i should be using both front and rear.... my dad is an excellant welder so the engine mounts should be easier enough to cut and reweld into place, < is that a good idea??? sorry for all my questions but i have been trying really hard to research, and also this is my first RWD experience lol... cheers in advance Report
December 29, 200718 yr comment_217115 you would probably have to massage the tunnel out with the W series box. i'd suggest the CA18DET if you can get a running front cut. since the 4age never came out turbo its a little harder to get all the parts together. as for the diff, you could get a borgwarner commodore diff cut down which gives you plenty of ratio choices and lsd centres are available and would come with rear discs. Report
December 29, 200718 yr Author comment_217120 ^ life saver lol, i am part of so many forums and that is the best answer i have heard LOL... so the CA18 i can get from my uncle includes gearbox, so i would have to "massage" the tunnel for it to fit right?? and i can get a borgwarner Diff frfom which model commo??? the rear disks are a great thing lol.... thanks heaps mate.... Report
December 29, 200718 yr comment_217131 check out the rides & projects thread for some other ke30-55's that have ca18's in them, most people have pics of the stuff they've needed to do to the body and everything else. Report
December 29, 200718 yr comment_217163 my mate got a v8 VN borg warner cut down to suit his ke20 with brand new discs and brand new LSD for $2000. u will also need a computer (a standard ECU would come with a front cut) or you could get aftermarket (haltech/microtech etc) if you don't have a complete loom to use. fuel system, easy to use a surge tank filled by a high flow/low pressure lift pump from your original fuel tank and then use a high pressure pump to feed your fuel rail. check your stock fuel line size. you will also need some decent front seats to hold you in place. front brakes / wheels engineering write up a budget! Report
December 29, 200718 yr Author comment_217216 thank god I'm in no rush lol.... is the stock fuel line size going to be sufficent to power a turbo engine?? (only small power though) I'm not going all out like i don't want to drift just a tough little streeter.... GODDAMM budget.. lol... Report
December 30, 200718 yr comment_217344 with a turbo engine u will need larger fule lines a swirl pot (fuel catch tank) a lift pump and a preasure pump i don't think standerd fule lines will fule a 4age and what do you think a low powerd turbo engine is ca18et is what i'd call friggen fast engine in a ke55 just get a 4age and throw it in Edited December 30, 200718 yr by ae174agze Report
January 1, 200818 yr comment_217635 CA18DET WILL FIT A KE30-55 NO WORRIES NO CUTTING APART FROM A NEW SHIFTER LOCATION. Just need custom x-memeber to bolt it all. Rn10-13 hilux diff is the correct width or try any borg-warner commo diff ie-vl-vs or r31 skyline. Check my ke35 ca18 only runs a 12.41 with a slippin clutch though. Plently of info if you read up on my build good luck mate! Report
January 1, 200818 yr comment_217676 CA18DET WILL FIT A KE30-55 NO WORRIES NO CUTTING APART FROM A NEW SHIFTER LOCATION. Just need custom x-memeber to bolt it all. Rn10-13 hilux diff is the correct width or try any borg-warner commo diff ie-vl-vs or r31 skyline. Check my ke35 ca18 only runs a 12.41 with a slippin clutch though. Plently of info if you read up on my build good luck mate! the tunnel require modifiying? Was urs auto or manual to start? Report
