Turbo In Stock 3k
i want to put turbo on my 3K 1978 ke30 rolla i would get a bigger motor but then i have to go threw regencey n screw that so yeah if some 1 could help me that would be great
Edited by ke30Rolla myles
y not put a 7k or a 5k then turbo that?
...and bolting a turbo onto an engine that was never turbo'd from factory will mean you won't ever have to go thru regency???
OMG the slick turboo flutterz uleh.
occasionally a manifold to suit (or can be made to) turns up on ebay.
becuase if i change the moter then ill have to go to regencsey if i get pulled over
Yeh true if you drop a turbo in and get pulled over ull get done for the turbo, a 5k would be eaiser to hide and might not be such an issue with dept of road and transport if you change the engine number on the rego details. Give em a call.
Everyone is right there man - if you get pulled over with a turbo, you'll still get done.
drop a 5k in, it'll look stock enough that you wont need to worry about it. Plus you should be able to get it registered with a 5k anyway.
Just put the 3k-c stickered tappett cover on the 5k and the cops/transport will never look twice! :)
As for turbo'ing a K motor, there is plenty of info about this site. Like Irokin said in your other locked thread its pretty obvious you did absolutely no searching first!!!
ok thanks ill start looking into a 5k then
you should contact department of road and transport to ask the question
