December 14, 200817 yr comment_297794 someone please help just put 4age in my ke30 and timmed it perfect and idols good but when we put full throtle on it boggs out and the timing retards have cheaked almost everything tps dizzy air temp and ignotor all good and no error codes show up any one got any ideas?????? Report
December 14, 200817 yr comment_297807 i had a similar thing happen to mine when i did my convo, idled fine but rev it a bit and she'd die in the ass.... turned out to be the actual dizzy was somehow cracked inside or something and sent two signals to the ecu.. so may i suggest you try another distributor if you have one handy. Report
December 14, 200817 yr Author comment_297875 i had a similar thing happen to mine when i did my convo, idled fine but rev it a bit and she'd die in the ass.... turned out to be the actual dizzy was somehow cracked inside or something and sent two signals to the ecu.. so may i suggest you try another distributor if you have one handy. Yea we changed the dizzy cus the seal was f@$ked but still no change when we go 1/4 throtle it goes fine but wen we go full throtle it retards and runs like shit think it may be map sensor getting it cheaked tomorow thanks anyway. Report
December 14, 200817 yr comment_297877 Sounds more like the TPS (throttle position sensor), Check or Adjust it to the correct settings. Edited December 14, 200817 yr by Trev Report
December 14, 200817 yr comment_297939 I suggest you try setting the timing to a different position and see if it runs better. Report
December 15, 200817 yr comment_298060 Seeing that it drives fine at 1/4 throttle then really bogging down at full throttle, I would say it's TPS related. If it's bogging down in certain rev ranges, it could be anything to do with the ignition (plugs, leads, etc) or timing's out. Report
December 15, 200817 yr Author comment_298096 we tunned the tps using feeler gauge like the book says and seams overrated but il try again and if that doesnt work ill try another one the ecu doesnt show any fault codes thou. we replaced the leads plugs coil and dizzy nd no change. Report
December 15, 200817 yr comment_298295 Where are you located, I have several TPS's that you could try. Report
December 16, 200817 yr comment_298500 have you checked the fuel pressure? also the fuel pressure regulator. do you have a new fuel filter? Report
December 18, 200817 yr Author comment_299251 I'm in nz a we tried another tps but no change, put fuel preasure gauge on and thats fine to, some1 told me that they had the same problem but when they put a speed sensor on it fixed it any1 herd of this????? Report
December 18, 200817 yr comment_299275 are the IAC( idle air control ) water pipes connected? these are the ones connected to the throttle body. a lot of people disconnect them thinking it'll keep the throttle body cold, but it can cause problems. if not, connect them and make sure there is flow though it. have heard of the speed sensor giving problems, but not like this. how'd you set the timing? with terminals T & E jumped across? Report
December 19, 200817 yr comment_299394 the IAC valves get clogged with crap pretty easily. Pull it apart and soak the TB assembly in carby cleaner. Report
December 19, 200817 yr comment_299480 The idle control 'wax pellet' will not cause it to bog down at all. Report
January 4, 200917 yr Author comment_304040 i used gasket paper to block off the stuff at the botom of the throtle body cud that be a problem?? Report
