December 14, 200817 yr comment_297842 Hey guys, Just wondering, what is the difference between a KE30 And A KE55? Cheers Report
December 14, 200817 yr comment_297843 Hey guys, Just wondering, what is the difference between a KE30 And A KE55? Cheers this has been covered many times Report
December 14, 200817 yr comment_297897 cosmetic body changes mainly a dash upgrade, Air cond as an option, Australian content import tax laws saw a lot of Australian parts used, Borg-warner diffs, Bosch alternators and holden trimatic auto's Report
December 14, 200817 yr comment_297905 1290cc :jamie: Bigger brakes (rear) aswell i think. Edited December 14, 200817 yr by SLO-030 Report
December 14, 200817 yr comment_297907 I have a ke 30 with under-dash aircond I think ke55 was the first ducted Factory air cond. Report
December 14, 200817 yr comment_297908 Oh god do I have to explain again... You would find it if you did a search but anyway... Engine upgrade, 3K to 4K, intrusion bars in doors (Car now heavier hence engine increase), bonnet change, grill change, rear demister now standard, foam door handles now standard, material used in cloth seats changed, design overall with seats changed -now comfier and has a knob to adjust ,bumpers changed, rims changed,braking system was upgraded, center console now standard, diff change, rear vent changed, chrome mud flaps on front guards now gone, steering wheel changed, There could be more but I'm tired. Report
December 15, 200817 yr comment_298302 Oh god do I have to explain again... You would find it if you did a search but anyway... Engine upgrade, 3K to 4K, intrusion bars in doors (Car now heavier hence engine increase), bonnet change, grill change, rear demister now standard, foam door handles now standard, material used in cloth seats changed, design overall with seats changed -now comfier and has a knob to adjust ,bumpers changed, rims changed,braking system was upgraded, center console now standard, diff change, rear vent changed, chrome mud flaps on front guards now gone, steering wheel changed, There could be more but I'm tired. How are the rims different? They look the same to me :jamie: Report
December 16, 200817 yr comment_298392 If you look closely the KE30 ones are a thinner rim and the hole in the center is almost like a tunnel. About 2cms. Report
December 16, 200817 yr comment_298399 If you look closely the KE30 ones are a thinner rim and the hole in the center is almost like a tunnel. About 2cms. ^^^ this man is correct. they changed centre caps also. the early ones have clips that grab onto the centre tunnel, the late ones press on and just "hug" the centre tunnel. i have pics if necessary to show the centre hub difference. dF Report
