January 6, 200917 yr comment_304926 hay guys and gurls how hard is it to put an A series bellhousing on a K series 5 speed box?? and were can i get it done in qld Edited January 6, 200917 yr by mr ae71 Report
January 6, 200917 yr comment_304937 this isn't helpful but i'm curious as to why you would wanna do that??? wouldn't it wanna be the other way around? stronger motor on a weaker box?? Report
January 6, 200917 yr Author comment_304949 beacuse i'm chasin a gearbox so i can get my car going again asap because i'm renting the house an my lease runs out soon Report
January 6, 200917 yr comment_304976 hay guys and gurls how hard is it to put an A series bellhousing on a K series 5 speed box?? and were can i get it done in qld Anything can be achieveable at an engineering shop and some funds available, but id say if you already have an AE71 just get a T50 box from another AE71 it will be cheaper. Ask a few AE71 drivers in your local area or even the local toyota wreckers they might be more helpful if all you want to do is get your car going again. Report
January 6, 200917 yr comment_305037 A K series box is a single piece bell housing and gearbox housing unlike the T series which is a three piece. This means that No not easily can you adapt an A series bellhousing to a K series box. Unless you do a cut and shunt which will cost mega $$$, like previously stated even a second hand T50 would be cheaper. Try this instead, if you have one T50 from an A Series, you can buy a T50 from a T series very cheap,(I keep them as spares for my rally car as they are chaper, I am unaware of any mechanical difference of power rating difference) the only difference is the bellhousing and rear connecting section which are interchangable between the A and T series T50 boxes. SO you can just swap your A housing from the existing box and just stick them on a T series T50 of which there are heaps floating around. Hope this helps Report
January 6, 200917 yr Author comment_305121 A K series box is a single piece bell housing and gearbox housing unlike the T series which is a three piece. This means that No not easily can you adapt an A series bellhousing to a K series box. Unless you do a cut and shunt which will cost mega $$$, like previously stated even a second hand T50 would be cheaper. Try this instead, if you have one T50 from an A Series, you can buy a T50 from a T series very cheap,(I keep them as spares for my rally car as they are chaper, I am unaware of any mechanical difference of power rating difference) the only difference is the bellhousing and rear connecting section which are interchangable between the A and T series T50 boxes. SO you can just swap your A housing from the existing box and just stick them on a T series T50 of which there are heaps floating around. Hope this helps thank you very much mikey_m you hav saved me alot of time and $$$$ Report
January 6, 200917 yr comment_305159 Or if you're intent on using a K-box (for some insane reason), track down a K-box from the US which was behind a 3A POS in the AE85.... Edited January 6, 200917 yr by Hiro Protagonist Report
January 6, 200917 yr comment_305163 thank you very much mikey_m you hav saved me alot of time and $$$$ Umm,........and he may cause you some greif too!!!! :y: What Mikey has told you there is not complete correct, although he slightly touched on the problem. T series T50 (from TA22 and TE72) have a forward shifter position (like a ke30/55) and a 20 spline output shaft. A series T50 (from AE71 and AE86) have a rear shifter position (like a ke70) and a 22 spline output shaft. So if you were to put the T series T50 into an A series car you would need to change the spline on the tailshaft, and cut the hole in the trans tunnel further forward - possibly causing a world of greif with the lower dash!! Alternatively - Track down another A series T50 and it'll bolt straight in with no extra work. :y: Report
January 6, 200917 yr Author comment_305186 Umm,........and he may cause you some greif too!!!! :y: What Mikey has told you there is not complete correct, although he slightly touched on the problem. T series T50 (from TA22 and TE72) have a forward shifter position (like a ke30/55) and a 20 spline output shaft. A series T50 (from AE71 and AE86) have a rear shifter position (like a ke70) and a 22 spline output shaft. So if you were to put the T series T50 into an A series car you would need to change the spline on the tailshaft, and cut the hole in the trans tunnel further forward - possibly causing a world of greif with the lower dash!! Alternatively - Track down another A series T50 and it'll bolt straight in with no extra work. :y: cuttin holes in stuff has never worried me :D thanks for the advice bud, so i would need a celica tailshaft aswell if i used the celica t50 Report
January 7, 200917 yr comment_305234 hey man nah i don't think you do i think you actually use the k series tailshafts if i recall? Report
January 7, 200917 yr comment_305279 hey man nah i don't think you do i think you actually use the k series tailshafts if i recall? Correct - I keep and A and the original K one, never know which one is which, but works for me everytime. Report
January 7, 200917 yr Author comment_305426 cheers boys mayb i'll just ditch the a motor and put a 3t in it or somethin in my rolla for the time being just to get it goin Report
January 11, 200917 yr comment_306645 T series T50 (from TA22 and TE72) have a forward shifter position (like a ke30/55) and a 20 spline output shaft. TE72's have the 20 spline output, but have the rear shifter position, I mean they share the chassis as KE70 and AE71's and as such the same shifter position. By far the easiest way to get a KE70 running with an A series motor is to get a K50 box from a Jap AE85. They still run a cable clutch so no messing around with pedal boxes etc. One of the sponsors on DC has one I think, although they wont take that much, might just survive with a stock 16v 4AGE. Report
