  • Replies 73
I did.
Not the best pic but when I checked this morning there was coolant sprayed all over the place. This after noon I tracked it to the top radiator hose where it meets the engine. I tightened it this afternoon and will see tomorrow if it still leaks.
You aren't really having a good run with that motor are you JiP ?
If you get sick of it, toss it my way. And as payment, you can mow my backyard for me.
How old's the hose ? Cause they can deteriorate on the inside to such a point where they'll leak and/or split or burst
Yeeeep me thinks its a fair trade :dance:
I'll take your problematic motor and you can have my problematic back yard to mow each and every week :y:
But anywhat, i'd start thinking of new top and bottom hoses if the leak comes back again once too often. Not really all that good on the hose if you have to keep tightening the clamp up.
I can't really see it being the clamp itself coming loose but it might even be worth a shot in swapping it over with the one on the radiator and seeing what happens..
And this was meant to be a temporary fix until you got the money to get another car registered and pull the 5k out and freshen it up, I did say to you that I didn't like removing a head just to do a gasket as there are chances of it needing machining altho most of the time a head will be square.
:dance: take the head off and skim it.
Yeah no shit but Jon needs his car, He can't just give it up, I told Jon I didnt want to do it that way but all he needs right now is a car that does not leak oil so he can park on job sites without getting into shit, Once he gets the money he is registering another car and taking the 5k out to get rebuilt.
Don't try to make out that I don't know what I'm doing, I did what the 'customer' wanted.
hrmm well the customer fails at life :dance:
if you need to keep it on the road the whole time track down a second head and get that all checked out john.
and if you need to swap it in a days work on the weekend should do it, hell i have pulling the head and putting back on again down to a hour tops now and ive only done it four times :y:
Jon came over today so I could look at it.
THE OIL LEAK IS NOW FIXED, IT WAS NUMBER 2 & 3 SPARK PLUG TUBE.
Edited by Trev
Yes it is now fixed. Now usually when you fix something, something else breaks. I just didn't know it'd be so soon. One of my HID's just died.
So i'll try to fix that in the next couple days. Then hopefully next week sort out the rest of the wiring.
And we realised that someone has broken the alternator sense wiring off of the alternator :dance:
It came from China. I have 2 spare kits, well only one now as i had to use one to fix Lolla this morning.
I checked the car this morning as i got to work and there is a small bit of oil dribbling from spark plug no.2. I think this arvo i'll buy new tubes and rings.
And also i'm parked on a nice clean stretch of road today so i'll see later if i continue to drip.
