February 24, 200917 yr comment_321974 What needs to be done apart from engine and box to convert a 4k KE55 4speed into a 5speed v6 legal requirements in nsw car needs to be daily Power to weight requirements also any other engines suggested that are 6s like should i do L27 (VP 3.8l) (130kw) or a LN3 (VN 3.8l) (123kw) or an L36 (VS 3.8l) (153kw) don't bother sendin me shit about other state legal requirements Report
February 24, 200917 yr comment_321997 What needs to be done apart from engine and boxto convert a 4k KE55 4speed into a 5speed v6 legal requirements in nsw car needs to be daily Power to weight requirements also any other engines suggested that are 6s like should i do L27 (VP 3.8l) (130kw) or a LN3 (VN 3.8l) (123kw) or an L36 (VS 3.8l) (153kw) don't bother sendin me shit about other state legal requirements I'm goin through it know. apaerntly it can't be done unless your in victoria. comes down to weight vs capacity. lucky I'm in vic and they have their own rules. thats what my engineer says Report
February 24, 200917 yr comment_322002 What needs to be done apart from engine and boxto convert a 4k KE55 4speed into a 5speed v6 legal requirements in nsw car needs to be daily Power to weight requirements also any other engines suggested that are 6s like should i do L27 (VP 3.8l) (130kw) or a LN3 (VN 3.8l) (123kw) or an L36 (VS 3.8l) (153kw) don't bother sendin me shit about other state legal requirements None of those will be legal in NSW Report
February 24, 200917 yr comment_322013 Been there done that. Put a turbo 4 in it man, Go heaps faster and easy to get legal. Report
February 25, 200917 yr Author comment_322235 do u kno the limits for the weight vs capacity then in nsw mite just have to change sum paper work around n live in victoria thats y i was thinkin the VN motor would work coz it is 123kw can anyone give me sum RTA or watevs info coz there site just gets me lost decoop give us some info on what u had to go thru would b saweet Report
February 25, 200917 yr comment_322238 do u kno the limits for the weight vs capacity then in nswmite just have to change sum paper work around n live in victoria thats y i was thinkin the VN motor would work coz it is 123kw can anyone give me sum RTA or watevs info coz there site just gets me lost decoop give us some info on what u had to go thru would b saweet If thats the case, then why would you put a 123kw commowhore boat anchor in when you could much easier put in for example a 4age 20v which has 120kw factory standard and weighs probably half as much. Keep the handling of the car as well as the power increase :no2: BTW punctuation, spelling and no sms talk go a long way around here too :hmm: Edit - And it would also be engineerable then as well Edited February 25, 200917 yr by KE ping it real Report
February 25, 200917 yr comment_322239 If thats the case, then why would you put a 123kw commowhore boat anchor in when you could much easier put in for example a 4age 20v which has 120kw factory standard and weighs probably half as much. One word - torque. That, and 20v RWD conversions are fairly annoying. Report
February 25, 200917 yr comment_322241 One word - torque. That, and 20v RWD conversions are fairly annoying. That was just an example, even a SR20de non turbo puts out around the same kw with more torque being the 2L once again engineerable power and then add the turbo version if you wanted and shitloads more hp and torque Report
February 25, 200917 yr comment_322254 Under the federal laws you can engineer 4 x the capacity. So it is possible to make it legal. QLD just went to the federal code, so It is feasible that the other states may follow suit. But yeah, if you like corners, there's piles of better conversions out there. 3VZ-FE is an overlooked option, but are a little bit like a 7M when it comes to gaskets. Report
February 25, 200917 yr comment_322258 That was just an example, even a SR20de non turbo puts out around the same kw with more torque being the 2Lonce again engineerable power and then add the turbo version if you wanted and shitloads more hp and torque I was implying that people put the V6 in for the torque, which is heaps more than you'll get out of a 20v, SR20 or just about anything else N/A for the price. Under the federal laws you can engineer 4 x the capacity. So it is possible to make it legal. QLD just went to the federal code, so It is feasible that the other states may follow suit. But yeah, if you like corners, there's piles of better conversions out there. 3VZ-FE is an overlooked option, but are a little bit like a 7M when it comes to gaskets. As far as I am aware, NSW has not adopted the NCOP. Edited February 25, 200917 yr by Hiro Protagonist Report
February 25, 200917 yr Author comment_322268 thanks guys mitsubishi produced a 1.6l miovec 4g92 that has 128kw a guy the other day was postin about a mirage conversion how bout a lancer conversion Report
February 25, 200917 yr comment_322272 Under the federal laws you can engineer 4 x the capacity. So it is possible to make it legal. QLD just went to the federal code, so It is feasible that the other states may follow suit. But yeah, if you like corners, there's piles of better conversions out there. 3VZ-FE is an overlooked option, but are a little bit like a 7M when it comes to gaskets. at this stage QLD still uses its own code so X by 3 for na ke55 sed is 930kg so even if you use national code 930 X 4 = 3720cc so how can they be legal. here,s a quiz for you name the car manufactures that still produce petrol engines with pushrods, i think it,s GM and lada, Report
February 25, 200917 yr comment_322287 At current QT has indicated 1 July 2009 as the date we will commence usingthe NCOP. Initially 1 January 2009 was the proposed date, however the AMVCB was not able to produce a finalised verison of the code that Queensland was willing to legislate. Regards _______________________________________ Peter Austin Assistant Policy Officer Vehicle Modifications, Standards and Safety P 3253 4778 | F 3253 4030 |E [email protected] www.transport.qld.gov.au One of the top hits on google atm. Yes it is happening. Putting a decent sized motor in your corolla will be an option in QLD in the coming months. In my opinion any federal law supersedes a state law. Well it looks like you need a 3.6L 180kw alloytech motor for it to be legal then ... what a shame. Report
February 25, 200917 yr comment_322298 One of the top hits on google atm. Yes it is happening. Putting a decent sized motor in your corolla will be an option in QLD in the coming months. In my opinion any federal law supersedes a state law. Well it looks like you need a 3.6L 180kw alloytech motor for it to be legal then ... what a shame. Nope. Doesn't work like that. The state has to become a signitory to the code. ATM it looks like NSW isn't going to adopt it, and one or two others may not as well. To give you an example, The National Traffic code came about in 1996-ish and was meant to standardise the traffic rules across the country. Only Qld and S.A signed up to that one. Report
February 25, 200917 yr comment_322314 Reminds me of the new metal health funding legislation that's meant to be coming in. If your state doesn't ratify to the protocol, making a dope smoker as bad in the laws eyes as a heroin junky, your state won't get there cut of the pie. One day the right people might get a grip that the world will never be a Utopian wonderland, only people with no real experience of the world are so naive. Report
