May 19, 201016 yr comment_438673 Yeah i imagine with a cam itd make more of a difference, my only mod is an exhaust (no extractors) Can you remember what combo of jets you used? I'm guessing 323 primary 929 secondries? Will have to learn how to pull the jets out first haha Report
May 19, 201016 yr comment_438687 Yeah I'm pretty sure that was it, nice guess, was a massive cam though. I also fitted a small bolt to the vacuum secondaries actuator to have them open a bit early too. Was an 88-42 cam or so I was told, extractors and 2 1/4 system. Was gutless down low but you would zoom past V6 commo's once it got on song. Edited May 19, 201016 yr by beerhead Report
May 20, 201016 yr comment_438829 So the stock jets were too big even with the mods you had? Interesting... this is making me want a cam lol.. Report
May 20, 201016 yr comment_438842 Anyone got pics of the crimping the accelerator cable bit? The extra pics on the first page don't work :rolls: Edited May 20, 201016 yr by blzbub666 Report
May 22, 201016 yr comment_439323 I just went to a push bike shop and got a screw down brake pedal cable attachment. Cut down the cable and bolt it on together with loctite. Report
May 22, 201016 yr comment_439325 Sorry I still can't see how it works. I get what ya all mean but struggling to visualise it. I'm guessing its to take up slack? Report
May 22, 201016 yr comment_439327 Here you go - Pics say 1000 words. You can get crimp on ones too. I Googled "bicycle brake cable end" Report
June 4, 201016 yr comment_442444 To put my experience of Nikki conversions to use, i used to own a RA28 Celica brought stocko with extractors then fitted a Nikki from a Datto 280c! Swapped to a 32/36 DGAV but lost power had it checked by a carb recoer who rejetted it but still no improvement! So i swapped back to the Nikki, then Saturday morn when i was at the local wreckers with a mate i noticed a Nikki sitting atop an old Mustard yellow 74 180B, not bolted down! Lifted it up just out of interest as it looked quite big, turned it over and was dumbstruck! Paid $20 for it at the counter and took it home, fiited it within half an hour and went for what i planned a short blocki to check if it was any better! 1/2hr later i returned jumped out in the driveway popped the bonnet and stood there shaking my head! Damn thing went like the stink, in that half hour i'd out run a mild port 12A RX2 and a mild 6cly VH to 100kmphr in a 100km zone! Speeding is Deadly ok!!! So if you want the best Nikki ever made look towards the early 180B and fit a weaker secondary vac spring so the secondaries open sooner! old Gemmi trick!!!! Report
June 5, 201016 yr comment_442621 Where would i be able to grab a different spring? i think mines missing altogether at the moment... Report
June 5, 201016 yr comment_442625 one member is saying that they are poo (clonk out before going around a bend) couple of member is saying mad induction and better fuel economy another member is saying go 180B carby I'm confused? Report
June 5, 201016 yr comment_442672 I'd advise if considering fitting a bigger carb to fit a vacuum gauge first. Hammer the car through the gears and take a note of the lowest vacuum reading gained. If you are getting 0-1" vacuum a bigger carb won't be of any benefit as the carb is not a restriction. If you are getting readings of 2" or more of vacuum, remove the filter and try again to see if the readings drop... If so the filter is the restriction, fit a sports element. If even without the filter you are pulling 2" or more of vacuum at full throttle through the gears, then yes the carb is a restriction and a bigger carb will be of use to your combo. I ran a stock rejetted 3k carb on the warm 5k in my car for a bit. It would pull 3-4" of vacuum at full noise through the lower gears. With my DCD weber it pegs the needle at 0" of vacuum... LOL, you can hear the ping of the needle as it hits the zero stop through the gears. Report
June 5, 201016 yr comment_442681 Where would i be able to grab a different spring? i think mines missing altogether at the moment... http://www.ausrotary.com/viewtopic.php?f=4&t=105645 here man this might help i started of thinking the spring was on the outside :) lol then google showed me the light hahaha there's some pretty interesting stuff Report
