Ford 2l Pinto Engine Into Ke30
I think he was implying that the Cosworth came first, and the 4AGE was based off it, therefore the 4AGE is a 1.6L Cossy. Other way around implies that the 4A came first, which it didn't.
Although actually, the 4A is supposedly based off the BDA (Belt-Driven A-series, which is based off the Kent), which is a 1.6L. The Cossy most people refer to is the 2.0L YB, which is based off the Pinto anyway.
there's the thread killer right there :y:
What's wrong with the old 2L pinto? Heaps of potential with performance parts fairly easy to come by.
I remember Brian Munroe running 9 sec quarters in his Mk2 escort with a turboed 2L SOHC motor back in the early 90's. Might see if I can find and scan the old mag articles, the guy was a true innovator.
Sounds like a good idea. Good torque. Even with the 1.6L Escort the power seemed OK for running around town (noticeable difference after driving the corolla with a 4K). The gearbox shifts nice and tight.
The bonus with the 2L pinto is that its got a 32/26 weber on the engine as stock; saw an engine in a Cortina out the tip the other day.
Edited by bruce
Lots of options with the 2l ford engine from simple as in one tooth advanced on the timing to a decent cosworth head. They are a good little engine with heaps of potential.
As much as I love the new Jap gear, not everything needs to burn rice!!
This might be an idea for the new ke30.
Twitchy: can you elaborate on this 1 tooth advanced thing?
  • 2 months later...
Sorry mate, forgot about this one..........
They used to advance the timing one tooth on the belt, lost a little power right at the top end but gained a fair bit through bottom end & mid range.
