Evan G Posted June 16, 2009 Report Posted June 16, 2009 i cannot find a 5 speed around (a cheap 5 speed) so I'm thinking about going 4 speed, but red dawf reckons my ears are gonna bleed on the freeway is it unbearable in a ke55 4 speed on the freeway????? thanks in advance Quote
love ke70 Posted June 16, 2009 Report Posted June 16, 2009 no its not! i ran a 4 speed for several weeks and it didnt bother me, fuel economy is not considerably worse either. just do it, i don't think you will be too bothered by it...light throttle isnt very loud which is what cruise will be like on the motorway Quote
Evan G Posted June 16, 2009 Author Report Posted June 16, 2009 (edited) no its not! i ran a 4 speed for several weeks and it didnt bother me, fuel economy is not considerably worse either. just do it, i don't think you will be too bothered by it...light throttle isnt very loud which is what cruise will be like on the motorway like I'm running a 3 speed witch only has 2 gears LOL hence wanting to do a manual conversion LOL yea f@$k it 4 speed it is QUESTION, will a 4 speed shifter line up in the old auto shifter hole? Edited June 16, 2009 by Evan G Quote
Bowler Posted June 16, 2009 Report Posted June 16, 2009 Correct me if I'm wrong, but you'll need a box out of a 70 for it to line up, but as people before have done, nothing an angle grinder can't fix... Quote
Evan G Posted June 16, 2009 Author Report Posted June 16, 2009 Correct me if I'm wrong, but you'll need a box out of a 70 for it to line up, but as people before have done, nothing an angle grinder can't fix... thats for a 5speed, I'm wondering for a 4 speed Quote
Evan G Posted June 16, 2009 Author Report Posted June 16, 2009 Correct me if I'm wrong, but you'll need a box out of a 70 for it to line up, but as people before have done, nothing an angle grinder can't fix... yea for a 5 speed you need a ke70 box, but a 4 speed out a ke55 line up with my ke55 auto shifter hole? Quote
colonel Posted June 16, 2009 Report Posted June 16, 2009 Both 4 & 5 speeds from ke30/55 had shifters in the same spot, likewise the ke70's were in the same spot as each other. Just different shifters between models. Quote
Evan G Posted June 16, 2009 Author Report Posted June 16, 2009 Both 4 & 5 speeds from ke30/55 had shifters in the same spot, likewise the ke70's were in the same spot as each other. Just different shifters between models. cool cool 4 speed it is Quote
sammo[RL] Posted June 16, 2009 Report Posted June 16, 2009 Considering that the 4 speed and the auto both have a 1:1 direct drive top gear, it should be no different on the highway. should turn the same revs, unless you change the diff, and therefore the diff ratio, but wouldn't make that much difference anyway... Quote
Nitephyre Posted June 16, 2009 Report Posted June 16, 2009 Nothing wrong with a 4spd.... if you don't want to hear your radio 8/ Quote
Evan G Posted June 16, 2009 Author Report Posted June 16, 2009 Considering that the 4 speed and the auto both have a 1:1 direct drive top gear, it should be no different on the highway. should turn the same revs, unless you change the diff, and therefore the diff ratio, but wouldn't make that much difference anyway... yea thats true, hopefully when i get my 15' on the rear should drop the revs a bit more Quote
Evan G Posted June 16, 2009 Author Report Posted June 16, 2009 Nothing wrong with a 4spd.... if you don't want to hear your radio :lol: LOL! 8/ if u look below what i have planned for car audio i don't think ill be able to hear a cop behind me :sob: Quote
philbey Posted June 16, 2009 Report Posted June 16, 2009 Pussies - I drove my toyoglide on the freeway for 12 months, every day to work and back. albeit at only 95kmh..... Man up the lot of you and get a louder stereo! Quote
