June 16, 200917 yr comment_352547 i cannot find a 5 speed around (a cheap 5 speed) so I'm thinking about going 4 speed, but red dawf reckons my ears are gonna bleed on the freeway is it unbearable in a ke55 4 speed on the freeway????? thanks in advance Report
June 16, 200917 yr comment_352563 no its not! i ran a 4 speed for several weeks and it didnt bother me, fuel economy is not considerably worse either. just do it, i don't think you will be too bothered by it...light throttle isnt very loud which is what cruise will be like on the motorway Report
June 16, 200917 yr Author comment_352569 no its not! i ran a 4 speed for several weeks and it didnt bother me, fuel economy is not considerably worse either. just do it, i don't think you will be too bothered by it...light throttle isnt very loud which is what cruise will be like on the motorway like I'm running a 3 speed witch only has 2 gears LOL hence wanting to do a manual conversion LOL yea f@$k it 4 speed it is QUESTION, will a 4 speed shifter line up in the old auto shifter hole? Edited June 16, 200917 yr by Evan G Report
June 16, 200917 yr comment_352572 Correct me if I'm wrong, but you'll need a box out of a 70 for it to line up, but as people before have done, nothing an angle grinder can't fix... Report
June 16, 200917 yr Author comment_352579 Correct me if I'm wrong, but you'll need a box out of a 70 for it to line up, but as people before have done, nothing an angle grinder can't fix... thats for a 5speed, I'm wondering for a 4 speed Report
June 16, 200917 yr Author comment_352581 Correct me if I'm wrong, but you'll need a box out of a 70 for it to line up, but as people before have done, nothing an angle grinder can't fix... yea for a 5 speed you need a ke70 box, but a 4 speed out a ke55 line up with my ke55 auto shifter hole? Report
June 16, 200917 yr comment_352589 Both 4 & 5 speeds from ke30/55 had shifters in the same spot, likewise the ke70's were in the same spot as each other. Just different shifters between models. Report
June 16, 200917 yr Author comment_352592 Both 4 & 5 speeds from ke30/55 had shifters in the same spot, likewise the ke70's were in the same spot as each other. Just different shifters between models. cool cool 4 speed it is Report
June 16, 200917 yr comment_352603 Considering that the 4 speed and the auto both have a 1:1 direct drive top gear, it should be no different on the highway. should turn the same revs, unless you change the diff, and therefore the diff ratio, but wouldn't make that much difference anyway... Report
June 16, 200917 yr comment_352605 Nothing wrong with a 4spd.... if you don't want to hear your radio 8/ Report
June 16, 200917 yr Author comment_352606 Considering that the 4 speed and the auto both have a 1:1 direct drive top gear, it should be no different on the highway. should turn the same revs, unless you change the diff, and therefore the diff ratio, but wouldn't make that much difference anyway... yea thats true, hopefully when i get my 15' on the rear should drop the revs a bit more Report
June 16, 200917 yr Author comment_352609 Nothing wrong with a 4spd.... if you don't want to hear your radio :lol: LOL! 8/ if u look below what i have planned for car audio i don't think ill be able to hear a cop behind me :sob: Report
June 16, 200917 yr comment_352611 Pussies - I drove my toyoglide on the freeway for 12 months, every day to work and back. albeit at only 95kmh..... Man up the lot of you and get a louder stereo! Report
