July 20, 200917 yr comment_360221 From the figures I've seen from boosted 5K's, I think 100kw @ wheels isn't out of the question if you tune it right Report
July 21, 200917 yr comment_360254 from a 3k? i don't think so, it would be pushing it Heard of a 3k making in the order of 170rwkw.......... on Avgas though. :P and this 3k made 244hp and ran a 12.7!!!!.... http://cgi.ebay.com.au/Ke30-3k-4k-5k-turbo...%3A1%7C294%3A50 Report
July 30, 200917 yr Author comment_362403 someone convince me to keep this thing I am not finding any power and the turbo is toast so that is off the table for now. Report
July 30, 200917 yr comment_362414 Have you got the turbo fitted? Here's some motivation for you.... Edited July 30, 200917 yr by Taz_Rx Report
July 30, 200917 yr comment_362422 i've always wanted to build a 3k turbo... i love the way the 3k's rev, a bit of boost and it would be a great motor... also nice thick walls in the block so you shouldn't have much trouble keeping it togeather even with abit of boost :D i wouldn't run a t25 or a vf10 (ihi from subie) (vf8 is even bigger btw) i ran a vf10 on my 4k and 5k turbo setups and IMO its quite a big turbo for a small non-crossflow engine, good for making decent power up top but i don't think thats what your after, i ran the vf10 in a smaller mazda housing to bring the spool time down aswell i'd be looking at a vj6 or vj13 off a mazda b6t if i was going to do a 3k you havent mentioned what you plan to do for your manifold? Report
July 30, 200917 yr comment_362462 T25 would see bigger top end power, but if your leaving the engine stock inside then i would stick to the IHI, or even a T2 nissan turbo for super response. u may be suprised here i don't think 100kw at the fly is out of the question as long as your tune is right. 100kw at the wheels i don't think so. regarding the ignition timing, if you cannot adapt boost retard than stick with locking the mechanical advance. easy and works. a reliable 10psi is attainable Report
July 30, 200917 yr comment_362585 T25 would see bigger top end power, but if your leaving the engine stock inside then i would stick to the IHI, or even a T2 nissan turbo for super response. u may be suprised here i don't think 100kw at the fly is out of the question as long as your tune is right. 100kw at the wheels i don't think so. regarding the ignition timing, if you cannot adapt boost retard than stick with locking the mechanical advance. easy and works. a reliable 10psi is attainable I think a T2 would be too small for even a 3k. T25 would be about perfect, if its a T25G then you might even feel a bit restricted in the top end. The 170kw 3k I mentioned above made around 140rwkw on PULP and 19psi. Was a Draw through setup too. Report
August 3, 200917 yr comment_363290 how bout a charged on you engine :hmm: this my car.I rebuilt it by my self. Report
August 3, 200917 yr comment_363313 Have you got the turbo fitted? Here's some motivation for you.... Ooooh looking sweet si. Aim high vagen!! go for a big cam and heaps of boost!! Although not the most driveable or fuel efficient my 5k makes high 90`s rwkw on a baby 8.5psi(aiming for 12ish) with a sc12 and efi. Go easy on the changes and burnouts and the gearbox might last a little while. Boosted "k`s" rule. stu. Edited August 3, 200917 yr by kickn5k Report
August 3, 200917 yr comment_363385 does that cooler setup work? i wouldnt think so because i thort all the fuel would flud at the bottom of the intercooler.thinkin of doing the same for mine if it does work. draugh through supercharges are faily good and cheap to setup. Mine makes around 70kw but my old one made 110kw in the pic below i am useing a amr300 witch is off a little front wheel drive. i think it would work great on a 3k :hmm: Edited August 5, 200917 yr by **chumps** Report
August 3, 200917 yr comment_363417 does that cooler setup work?i wouldnt think so because i thort all the fuel would flud at the bottom of the intercooler.thinkin of doing the same for mine if it does work. It would work chumps, no doubt about that.......... Its just a ticking time bomb though!!!!! charged kid - remove the intercoller IMMEDIATELY!!!!!!! ....did I make that attention grabbing enough!? Why (again :hmm:) - Because you're running a draw-through setup you're currently pumping your intercooler fuel of a perfectly mixed combination of fuel and air...... ready for combustion. If you happen to have a back fire, it will travel up the inlet manifold and cross over pipe and into the intercooler.... then bad things happen...... Or you might just 'blow the welds on your intake'. :) Report
August 4, 200917 yr comment_363426 .....but i use this setup with this intercooler few month aready.and withoult it will over heat. few track event i go for testing this setup....so far no problem......... Report
August 4, 200917 yr comment_363429 No it won't overheat. You might need to need pull a little bit of timing out, but not heaps. Do you even have a bonnet scoop over the cooler? cause if not its not doing anything anyway!! Look that's how it is, do you want to run the risk of doing some serious damage in your engine bay!? Its only matter of tiome before somethig goes wrong....... but hey, what would I know! :hmm: Report
August 4, 200917 yr comment_363479 :hmm: .............before the intercooler it a straight piping.and really over heat every track day what ever i retard or advance the timing.after 2 round in track sure over heat.after this intercooler fix in no more heat problem.and can burn out 5 to 8 minutes no problem. Report
