G'day all.
I was wondering if anyone knew off the top of thier head, the maximum current flowing through a 4A starter Motor upon start up?
Just need to make sure i'm using the right wires.
Stewart.
the motor rating might not mean too much because dc motors especially series motors like starters draw many times more their rated power during startup. However the only reason wire size would need to be taken into account is of voltage drop. They are just used for too short a time to heat up to a failure point.
My Denso copy reduction starter peaks at about 120A on crank when I checked it at TAFE, So it would be higher than that for a Bosch unit. Depends how much load it cops to spin the motor etc...
And yes, Bigger cables are good, Big voltage drop and lots of cranking is a good way to kill a starter motor.. Don't know how Toyota got away with the size they used on my KE70 from factory..
Thanks Guys.
(I also realise this should be in the electrical section. Apologies to moderators, i will get it right next time)
Edited by Gecko71
When I was looking at remoting my battery, I did a little research.
You should expect should bursts of 2-300A if I recall correctly.
I know I had no luck was looking for a 300 amp fuse and had to settlt for smaller. 150A I think I got (no longer have the car so I can't check!) which seemed to do the job okay.
cheers,
Slapper
Edited by slapper
