Gecko71 Posted September 2, 2009 Report Share Posted September 2, 2009 G'day all. I was wondering if anyone knew off the top of thier head, the maximum current flowing through a 4A starter Motor upon start up? Just need to make sure i'm using the right wires. Stewart. Quote Link to comment Share on other sites More sharing options...
Evan G Posted September 2, 2009 Report Share Posted September 2, 2009 starter wire the bigger the better (1/0 gauge) no voltage drop, good starting abilty Quote Link to comment Share on other sites More sharing options...
Sam_Q Posted September 2, 2009 Report Share Posted September 2, 2009 stock is only like 16 square mm, don't you think thats a bit of a crazy overkill? Quote Link to comment Share on other sites More sharing options...
Hiro Protagonist Posted September 3, 2009 Report Share Posted September 3, 2009 12V, ~1kw starter motor, means you'll be looking at roughly 80A, based off back-of-the-envelope calculations. Which to me would indicate 4 guage (~21mm^2) Quote Link to comment Share on other sites More sharing options...
Sam_Q Posted September 3, 2009 Report Share Posted September 3, 2009 I would also go the 4 guage, but don't forget to have a nice ground cable from near the block to the body! Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted September 3, 2009 Report Share Posted September 3, 2009 Oh, I thought they pulled a couple of hundred amps... Then again, I'd never looked at the starter and read the wattage... Quote Link to comment Share on other sites More sharing options...
Sam_Q Posted September 3, 2009 Report Share Posted September 3, 2009 the motor rating might not mean too much because dc motors especially series motors like starters draw many times more their rated power during startup. However the only reason wire size would need to be taken into account is of voltage drop. They are just used for too short a time to heat up to a failure point. Quote Link to comment Share on other sites More sharing options...
Evan G Posted September 3, 2009 Report Share Posted September 3, 2009 ^ the bigger the better :P I'm gonna get a auto elec from work to make me starter/alternator/earth wires in 1/0 gauge :D Quote Link to comment Share on other sites More sharing options...
Medicine_Man Posted September 3, 2009 Report Share Posted September 3, 2009 My Denso copy reduction starter peaks at about 120A on crank when I checked it at TAFE, So it would be higher than that for a Bosch unit. Depends how much load it cops to spin the motor etc... And yes, Bigger cables are good, Big voltage drop and lots of cranking is a good way to kill a starter motor.. Don't know how Toyota got away with the size they used on my KE70 from factory.. Quote Link to comment Share on other sites More sharing options...
Gecko71 Posted September 3, 2009 Author Report Share Posted September 3, 2009 (edited) Thanks Guys. (I also realise this should be in the electrical section. Apologies to moderators, i will get it right next time) Edited September 3, 2009 by Gecko71 Quote Link to comment Share on other sites More sharing options...
slapper Posted September 3, 2009 Report Share Posted September 3, 2009 (edited) When I was looking at remoting my battery, I did a little research. You should expect should bursts of 2-300A if I recall correctly. I know I had no luck was looking for a 300 amp fuse and had to settlt for smaller. 150A I think I got (no longer have the car so I can't check!) which seemed to do the job okay. cheers, Slapper Edited September 3, 2009 by slapper Quote Link to comment Share on other sites More sharing options...
