Sr20 Conversion To Ke55 Plus Rebuild Plus Pimpage
Yeah maybe i'll see how it goes man
  • Replies 642
  • Views 744.8k
  • few more small things ,stripped the intake manifold , was going to try polish this up but it was so very grainy,sanded a test area and tryed polishing it ,but it looked so crap that i gave up on that
  • pretty happy finished off the clutch pedal,,   welded on the pedal part       i made up a stoper plate and welded that on       couldnt find what i realy wanted to but ended up welding
  • Man this was an epic read. I came from Google looking for how to do an SR20 conversion and found the mother of all rebuilds..   THIS LOOKS AWESOME, to the point that I signed up to the forum just so
no worrys its there if you get desperate,
Did the engineer I suggested to you have much to say about it? He seems really nice when I have spoken with him over the phone.
Don't give up man :laff:
Nah man but hes on my list, he works pretty dam far from where i live ,so trying a few more that are a bit closer first.
got 2 to ring tomoroow and going to see a guy on thursday with a bunch of pictures to show a guy,trying my hardest not to give up!!!!!
just this is rediculous what i have to go thru just to get a bit of paper!!!!ill see where we at at the end of the week ,then may try your guy ,
Hay mate i have a idea may sound silly, but next time you talk to an engineer ask them about your limits, like power to weight ratio's blah blah blah, the motor is turbo right? The only reason i'm asking is cause when i rang the guy that will most probably end up blue plating my car, said for a ke70 a turbo sr may just be pushing the limit, but he said a turbo ca will be fine and i'm pretty sure a 70 weighs alot more than a 55 and that is up here in QLD, so next time you talk to an engineer find out what your power to weight ratio limit is, and just ask to see if you'd get away with a non turbo motor into the car, then ask would you get away with a turbo ca and if he says yeah turbo ca will be fine maybe a ca into the car 1st, then later down the track sr it after you've moved to QLD :laff:
His engine is fine. His allowed up to 2.4 litre turbo same as me with my ke36. They both come in at 900kg according to Vic
Yeah thats what they say , but even so just trying to get some one to have a look is a night mare,
heres how this week is going so far,sunday i called a guy, he actualy sounded half interested in having a look,
he even aske me if he could come out and check it out, sounds good to me yeah?,
so he siad give you a call back tuesday,tuesday comes no call,so i call back ,"sorry hes busy right now take a message"
yeah left a message, no call back,call again next day ,"sorry hes busy right now take a mesage?"yeah left a message"
no call back again, called back again 3rd time "sorry hes on the phone can you hold on?" yess ill hold," umm sorry hes going to be a few mintues ,get him to call you back in a few minutes what your number"gives number again and hangs up
no call back....
this is what I'm dealing with,these sort of c**ts,have no interest in helping out or geting back to you,welcom to victoria,
tomorrow being thursday i have a appoinment to go talk to a engineer at his work which is an hour and a half drive away ,taking pics and crap to show and tell , will tell yous what happens there....................
Edited by JDM55
I have an idea mate organise a unreg'd permit for the car say it's stock and drive the car to an engineer thats obviously the only way your going to get this car engineered :) just an idea
yeah that could help a bit ,but its not quite up to drive stage yet,
i got the engine in mounts done,
gearbox in mounts done,
drive shaft in
drive shaft loop done
shortened diff fitted
airbox set up done,
hydro clutch done
strengthing done ,intercooler stuff done plus heaps
a ltittle things but yeah drive line is basicly ready just need the mounts checked from an other engineer,
hopefully it wont be a drama but hasnt been the best week so far so don't hold much confidence intomorows
visit
Are any of them even telling you their reasons why they don't want to do it? Or just making up excuses without a reason?
That guy you said that kept changing his mind, makes you wonder how he ever gets any cars approved if he can't even work to the guidline hey
it makes me wonder how he even got his degree!but rather i think he was deliberatly stuffing round as there was no intention of passing me ,well thats how it seemed to me,
Hi, some people on here are giving the wrong info, i think there are people reading this that are having a good giggle, get a copy of the rules for your state, you will find it is legal to do your conversion you just have to play by the rules, i've just read through and i can find a few things that just aren't passable, if you do it right as per the rules it will pass, banging your head and getting up people usually just ends up with you getting a headache
Edited by curly
Thanks for that but i have being doing right by the rules in the first place,i didnt start this project with out consulting if my engine would be legal or not,every one i spoke to said its fine under the power to weight ratio ruling,i was even working with an engineer at the start, how ever engineers in victoria are off there heads,they all have there little things they don't like etc due to the fact that they can interperate the rules as they see it making any middle ground between the different ones very hard to find,also to any one having a laugh at my problem,
GET F@#$K#$ come to victoria and try building a car with all the rediculous crap we have to deal with down here and see if your laughing then c**ts
Well i do blue plates and i was trying to give you some friendly advice but with your attitude you can stick your corolla, they will still be laughing and i'm sure you will get the outcome you deserve, HINT have a look at your brakes then check the rules, unsubscribed!!!!!
I'm starting the think all of these problems you are having might be related to that attitude shown just now.
Most of the things you said the engineer has a problem with have been engineered on plenty of other cars. Oh and curly is a pretty smart dude and knows his rollas but i guess you don't need his help and you have it all under control.
