October 24, 200917 yr comment_384899 as you know my ke55 coupe is my first car and my radioator has got a pin size hole where it is leeking fluid from what should i do weld it close or use metal filler open what is best for it to solve this problem Report
October 24, 200917 yr comment_384907 as you know my ke55 coupe is my first car and my radioator has got a pin size hole where it is leeking fluid from what should i do weld it close or use metal filler open what is best for it to solve this problem Go to a radiator shop and have it recored, that will cost around $275. Or you could take it to them and if the hole isnt a big issue they might just braise it shut. Id steer clear of adding any stop leak shit unless you were stuck on the side of the road somewhere. Report
October 24, 200917 yr Author comment_384909 Go to a radiator shop and have it recored, that will cost around $275. Or you could take it to them and if the hole isnt a big issue they might just braise it shut. Id steer clear of adding any stop leak shit unless you were stuck on the side of the road somewhere. the pin size hole is in the corner of the out let on the water tank at the top ,the core is fine and in good nick Report
October 24, 200917 yr comment_385005 yeh solder it, don't braise as you will probably remove the solder that is already there Report
October 25, 200917 yr comment_385409 If you want to be a tight arse then go and find a product by permatex called "need it". Its a 2 part epoxy putty thats made for fixing small leaks in radiators and fuel tanks. :S Report
