ke cruzer Posted October 24, 2009 Report Share Posted October 24, 2009 as you know my ke55 coupe is my first car and my radioator has got a pin size hole where it is leeking fluid from what should i do weld it close or use metal filler open what is best for it to solve this problem Quote Link to comment Share on other sites More sharing options...
LittleRedSpirit Posted October 24, 2009 Report Share Posted October 24, 2009 as you know my ke55 coupe is my first car and my radioator has got a pin size hole where it is leeking fluid from what should i do weld it close or use metal filler open what is best for it to solve this problem Go to a radiator shop and have it recored, that will cost around $275. Or you could take it to them and if the hole isnt a big issue they might just braise it shut. Id steer clear of adding any stop leak shit unless you were stuck on the side of the road somewhere. Quote Link to comment Share on other sites More sharing options...
ke cruzer Posted October 24, 2009 Author Report Share Posted October 24, 2009 Go to a radiator shop and have it recored, that will cost around $275. Or you could take it to them and if the hole isnt a big issue they might just braise it shut. Id steer clear of adding any stop leak shit unless you were stuck on the side of the road somewhere. the pin size hole is in the corner of the out let on the water tank at the top ,the core is fine and in good nick Quote Link to comment Share on other sites More sharing options...
anastasios Posted October 24, 2009 Report Share Posted October 24, 2009 i used solder to repair mine Quote Link to comment Share on other sites More sharing options...
kangaroosa Posted October 24, 2009 Report Share Posted October 24, 2009 Clean the paint off and solder it. Quote Link to comment Share on other sites More sharing options...
kiahn Posted October 24, 2009 Report Share Posted October 24, 2009 yeh solder it, don't braise as you will probably remove the solder that is already there Quote Link to comment Share on other sites More sharing options...
Evan G Posted October 24, 2009 Report Share Posted October 24, 2009 jb weld then duct tape ontop? Quote Link to comment Share on other sites More sharing options...
Taz_Rx Posted October 25, 2009 Report Share Posted October 25, 2009 If you want to be a tight arse then go and find a product by permatex called "need it". Its a 2 part epoxy putty thats made for fixing small leaks in radiators and fuel tanks. :S Quote Link to comment Share on other sites More sharing options...
