June 30, 200521 yr comment_54514 Yeah I'm thinking to bite the bullet and just swap the whole axle out of an ae86 in. I know plenty of people with experience in this swap and then i also get rear disc brakes and an lsd centres are available for it as well are you still running 4x110 or have you converted to 4x114.3 Thats the only oversight I can think of. Report
June 30, 200521 yr Author comment_54577 I'm a bit confused with the above post what are you referring to? Report
June 30, 200521 yr comment_54581 If you have a pure unadulterated KE20, the wheel studs will be 4x110 (Mazda RWD) pattern. All Corollas KE30 and newer (including AE86) have 4x114.3 pattern. Hence your current wheels wont fit. Report
July 1, 200521 yr Author comment_54857 oh right yeah ive got straight ke20 wheel stud pattern at the moment Report
July 2, 200521 yr comment_55110 Sounds to me like you need a set of U code ke2x series axles with a ke70 3.9 in it then buy TRD`s 5.1 trd lsd minus the 5.1 ratio(if he`s prepared to separate) then you`ll have same wheel stud pattern as std a stronger 6" set of final drive gears and a competition lsd centre on your 3.9.This setup takes a lot of punishment and keeps the car std and is very easy to do all bolt ups. :P Report
July 3, 200521 yr Author comment_55198 yeah mate thats exactly it how much $$$$$ will this trd diff set me back? Report
July 3, 200521 yr comment_55203 it's all here. http://www.rollaclub.com/board/index.php?showtopic=3361 Report
