My Advice On Die Grinders
OK guys,
for the past few days Ive been working on my new head. I'm porting it myself first...before any other work happens so that if I breach the port walls I havent lost $200 on spring and valve work.
Ive been using my "dremel" I picked up from supercheap for $39
My advice is don't waste your money on these. Spend over $100 and get yourself a decent die grinder.
Mine overheats frequently and has other issues...such as bearing shake (have to hold the case so that it doesnt vibrate and loose rpm.
Just spend the extra money and get it right the first time!!
I've got one of these too, and yes don't bother with them, they're shit. Good for small jobs here and there but they do overheat and they have no torque which makes it hard to do anything because it loses speed the moment you start doing anything... I've even given up trying to polish anything with it...
Also make sure that flex extension is sort of straight, if it is kinked in anyway it heats up REAL quick!
Mmmm Die grinder :D
Screw that, I need an Espresso machine before I get a die grinder :)
hehe...Ive got one...
cept I went back to instant...too much f@$king around
I use a dremel its pretty good better than an air grinder. :D
mmmmmmm espresso, or lattè for me .... any takers - my machine cost more than my rego - is that a bad sign ???
