Queen20v Posted January 17, 2010 Report Posted January 17, 2010 As the topic states, I'm after a diagram just to help me unlock the door with a coat hanger. :dance: If I didn't have bloody solex locks I'd bust in with another ke key. Thanks in advance for any help. Quote
Evan G Posted January 17, 2010 Report Posted January 17, 2010 is there a trim that goes along the window? remove that and stick the coat hanger down a bloke from work broke into my ke55 in 40 seconds :dance: Quote
SLO-030 Posted January 17, 2010 Report Posted January 17, 2010 What sort of car is it? Usually you bend a coat hanger into a "U" shape. Slide it down the side of the window and get the end of the U under the window and on the other side of it. from there try to position it under the dropper and push it up from underneath. Quote
JOLUF1 Posted January 17, 2010 Report Posted January 17, 2010 if u have raa give them a call they will come to u and open it.. Quote
rob83ke70 Posted January 17, 2010 Report Posted January 17, 2010 piece of packing strap, slide a loop of it in between the door and the body (where the rubber is) so you are holding both ends, wiggle it down to the door lock button, hook it around the button, and with some creativity, pop the button up. I've seen little bits of sandpaper attached to the packing strap or even sticky tape, depending upon creativity. If you are patient enough and talented enough you don't need any extras, just that blue packing strap. No damage done to the car either. there will now be a whole spate of corollas stolen :dance: Robert. Quote
Funking-Awesome Posted January 17, 2010 Report Posted January 17, 2010 Call Alchin locksmiths. And say that knight locksmiths sent you! Hahahaha :dance: Quote
SLO-030 Posted January 17, 2010 Report Posted January 17, 2010 Just remembered, KE2x don't have the droppers on the top of the door. They have them in the door handle. Could be a bit tricky :dance: Quote
TE278U Posted January 17, 2010 Report Posted January 17, 2010 piece of packing strap, slide a loop of it in between the door and the body (where the rubber is) so you are holding both ends, wiggle it down to the door lock button, hook it around the button, and with some creativity, pop the button up. I've seen little bits of sandpaper attached to the packing strap or even sticky tape, depending upon creativity. If you are patient enough and talented enough you don't need any extras, just that blue packing strap. No damage done to the car either. there will now be a whole spate of corollas stolen :dance: Robert. KE25 don't have a knob at the top of door... operated by lever next to internal door handle Quote
TE278U Posted January 17, 2010 Report Posted January 17, 2010 Queen, I'm assuming that this is on the 25, if perchance the rear quarter glass is open, i have used a 1m ruler to open my car after not having keys with me. hope this helps. Quote
Queen20v Posted January 17, 2010 Author Report Posted January 17, 2010 Thank you all. :dance: Ended up using a friend's RAA membership. The guy got it unlocked and then proceeded to eagerly open my door onto the brick wall. Now I have a chipped door. Ohhhh FML!! Honestly though, I'm just glad to have it open :y: Quote
camcam Posted January 17, 2010 Report Posted January 17, 2010 Thank you all. :dance: Ended up using a friend's RAA membership. The guy got it unlocked and then proceeded to eagerly open my door onto the brick wall. Now I have a chipped door. Ohhhh FML!! Honestly though, I'm just glad to have it open :y: awwww m,an that would piss me off lol Quote
JiP Posted January 17, 2010 Report Posted January 17, 2010 Wrong wrong wrong. She asked for a diagram. Now as I am very skilled I did a very detailed diagram... :dance: Quote
Jason KE30 Posted January 17, 2010 Report Posted January 17, 2010 You have way to much time on your hands Jon. Nice diagram though :dance:. I'll give it a B- Quote
Dropz Posted January 17, 2010 Report Posted January 17, 2010 Thank you all. :dance: Ended up using a friend's RAA membership. The guy got it unlocked and then proceeded to eagerly open my door onto the brick wall. Now I have a chipped door. Ohhhh FML!! Honestly though, I'm just glad to have it open :y: They should have insurance for that sort of stuff. accidental damage etc etc. did you enquire about it when he did it? Quote
JOLUF1 Posted January 17, 2010 Report Posted January 17, 2010 i would be making raa fix the chip he left in your door. glad to hear u got it opened. i once went to the bay to fly my kite while waiting for my girlfriend to finish work and locked my key in my vl had to run to her work and back incase i missed the raa man. Quote
