looking for a g63b engine for mish truck an came across a familiar auto trans bolted to an engine block
sure enough it had a "teg" cast into it. i couldn't identify it (upside down, no head) when i flipped it, i found it was a 6 cylinder
5m was stamped in the id plate
now this engine isn't very long....i think it would fit in a 7 series.....
Edited by mikeys toy
The Falcon SOHC 6 have the same problem the alloy heads heat and cool diffrently to the cast iron block causing distortion, allowing the head gasket to blow out. A sure tell tale sign is coolant dripping between the block and the head very common problem. That aside the M series as Super Jamie pointed out aint bad as long as they are maintained. Getting good power out of them isnt hard either :D
Hey, that's what's happeninig with my 3SFE... Except, it's like not just dripping, it's a bit of a shower in there...
