4k-5k Fuel Pump
Just a quick question...
I'm rebuilding a 5K but only have a fuel pump off a 4K.
Will a 4K fuel pump work on a 5K?
Thanks
You can buy these brand new, which i recommend
That's a relief!
I was unsure, so figured I should find out first. The engine itself is with a mate and it's a LONG drive away, so I did'nt want to get stuck and not have the right parts.
Thanks
Just make sure you take the spacer plate that goes between the block and fuel pump with you. Otherwise you will break the arm on the pump in no time!
The spacer plate is the plastic bit with a gasket on either side?
The one from the 4K fuel pump actually came off in several pieces, I guess they're prone to breaking. I've ordered a full gasket set for the 5K engine, so maybe another spacer plate is included?
Thanks
no spacer plate included in gasket kit,
Thanks
You can buy just the spacer plate and two gaskets for under 10 bucks!
cheers phatke30!
Will have to get the spacer and gaskets separately then.
Cheers guys
  • 5 weeks later...
a parts listed 5k fuel pump is much different to a 4k fuel pump when compared side by side.
a 4k fuel pump does fit.
anyone know if a 3k fuel pump is do the trick on a standard 5k?
cheers, scott
The part number for the spacer is Fuelmiser fpi-256, Bursons don't stock them but Repco do.
You get 1xspacer 2xgasket.
Andy
