hi, i have a ke55 that came as an auto. all the manual cross members don't fit my floor pan and the mount on the gear box is about eight inches to far forward. just curious if anyone knows why this has been such a pain in the ass.
what manual crossmember are you using? you'll need one from a ke30 or ke55, as well as a gearbox from the same
there should be two sets of chassis rail holes for you to bolt the gearbox crossmember to, 80mm apart. perhaps one of our members with a ke3/5 could stick their head under their car and tell you which set to use for a K box, i believe it's the forwardmost set
The plate around the shifter also needs to be changed, big pain in arse. Just drill out the spotwelds on both cars and swap the plates and i just used alot of silicone and rivits to reattach it. Welding would probably work just as good and look abit better though. Gearbox mounting points should be the same. They were for me anywho.
Edited by Stiks666
In fact I have had 16 gearboxes in my KE35 and they have all been identical....I have had an auto KE55 that I was going to put a manual in and no holes lined up with anything with any cross member I had....But we have put a KE55 4 speed into a KE35 auto, and everything bolted straight in. (apart from the shifter hole, which we just bashed out with a hammer haha)
Edited by Rolla__Boy
thats what i mean. this was an auto and theres just no holes there that line up. need the to get rwc with the manual but was just hoping there was another crossmember. does any one know some one that can fix this problem in victoria.
My KE30 was originally an Auto, and now has a 5 speed - K50.
There are different extension housings that may be causing your drama's. The KE70 extension housing has the shifter further back towards the rear of the car. It also has a different setup for mounting the gearbox crossmember.
If the following pics don't help. Then contact Peter Robinson below.
Call Peter Robinson on 9544 1162. He's in Clayton, VIC.
Tell him your story. Or even better, drop in. He can be a bit grumpy if you don't have all info together. In other words, make sure you clearly state your problem.
This pic is of a ke30/55 extension housing. Note the shifter is further foward and it just has the one bolt to attach the cross member rubber mount.
Edited by kangaroosa
KE70 extension housing. Note the shifter is further back. It also a different mount setup (2 bolts either side). This NOT the one you need. Or maybe it is, if nothing else has worked.
