We Can Rebuild It
R31 diff = VL diff = a lot of other Commodore/Falcon diffs. Cheap, easily available, lots of ratios (in the wrong direction, ie 3.9's etc), handles good power, but wears out quickly and doesn't work anywhere near as well as most other LSD's.
  • Replies 39
  • Views 10.2k
I was expecting to go in the wrong direction ie;3.9,3.7
Is the conversion of the Fseries as easy as an r31
Am i on the right track in thinking that with an excess
of torque lowering the diff ratio is benaficial.
It was hitting fifth gear at 50K's and was wanting to accelarate
going uphills at just ordinary revs. Basically if you
hit a steep hill at 80k it would accelerate when you
raised the revs.
(SLOTH'S HILLCLIMB SPECIAL)
it would accelerate when you raised the revs.
umm....thats what usually happens...you kinda have to have the revs rise in order to accelerate...you know...with that whole engine being connected to the wheels thing....
It has a 4.1 borg warner
Where do i find the gaerbox I.D
I think it has the van box in it.
Seems like very close ratio gears.
you kinda have to have the revs raise to accelarate
normally the load added by the hill will compensate
for the rise in revs ie; load +revs = velocity
  • 6 months later...
sorry to dig up a old thread but could i get a copy of dyno 2000?
ah, does your clutch normally slip? :)
i think it should be load + throttle = revs = velocity
I have 81mm Hypertec Pistons in my 5K. They were packaged for a Gemini (they required machining though). They might be a cheaper option than genuine pistons........ if you need new pistons.
If you havent found someone to do your headwork:
Call "Eddie Woods"
THE HEAD STUD DEVELOPMENT COMPANY
31 Capella Crs Moorabbin 3189
(03) 9553 2517
He knows his stuff when it comes to corolla heads and engines.
I just emailed you a copy of Dyno2000.
you can buy 5k .5 o/s hypatec pistons in flat top & dish types. are gemini ones stronger??? i just priced them yesterday. quite cheap i thought about $160 + as for the thurst washers for a 7k their the same as 5k,3e,5e & 1nzxe toyota engines. as for the 7k pistons the deck height is different from 5k & the the pin is 20mm, i just measured that against a 4age piston (100kw type) & the deck height is 2 mm short but no big dish in the piston. this would give ya a really strong piston with a full floating pin. compression ratio you would have to check but i couldn't see it being a problem. iam working on trying to find arp main bolts,head studs & rod bolts at the moment. when i find out what fits i'll post it UP
hope this is of some help to all
thanks Nick it is an awesome program
