Engine Ideas?
howz it going, got a KE70 and wanna get a bit more power out of it to atleast make it slide in the dry, but don't wanna spend big amounts and don't need HUGE amounts of power out of it.
just wanna know what people think as far as engines or mods?
its a 4k 5 speed, should i mod it?
some people say 3k head, webbers and extractors and be good
some say just go a 5k? how much better are they?
efi conversion?
any other cheap ideas? mods or conversions?
probably not 4age unless really cheap... or even CA18 or whatever
Just forget it- You'll get blisters on your right hand!
You're dreaming if you think that 1300cc from fifty years ago will ever make enough power to slide in the dry! Its a pathetic motor design that was 10years behind Datsun's SOHC 1600 in 1969, and 20years behind the twinkies 16valves... and that was thirty years ago!!
Spend a couple of days looking through the site to see who slides their car and what they did. If you have $10grand to spend then chase something at least 2litres and spend 1/3 of that money on the suspension. If you don't have $10k to throw at it get some fluffy dice and a dildo gearshift.
There are some good posts about diesel squirters or detergent pumps on the rear tyres.... :laff:
supercharged and worked 5k might do it will defiantly have the torque
weber 32/36 or go all out and use a 48 weber or dellorto
cam
pistons
valves
springs
timing belt
sc12 or sc14 supercharger
like the picture
if you can get the parts cheap and have mechanical knowledge would be great to do but don't expect fantastic or huge h.p but it should slide well if you know what you are doing
Timing belt?
BAHAHAHAHAHHAHAHAHAHAHAH ! :lol: thats f@$king gold!
Timing belt?
sucks to do all that work and only to have the timing belt snap
may as well change it
K-motors have timing chains, not timing belts.....
Aww... but the idea was good! and there's nothing like the scream of a supercharger when you nail it.
How mechanical are you MadRolla?? Can you build a motor yourself? Mod it?? Fabricate fittings for a supercharger??
How about dropping in a Suzuki Swift engine? That will give you a modern high-revving motor as an alternative to the 4AG-E.
Named "Swift Sport", it is powered by a high-revving 1.6 litre, naturally-aspirated DOHC VVT 4-cylinder engine with a 11.1:1 compression ratio, 4-1 exhaust manifold, High lift cams, Forged pistons, and strengthened valve springs. The 1.6 L engine produces 125 PS (92 kW; 123 hp) at 6600 rpm and 148 N·m (109 lb·ft) torque at 4800 rpm.
There will be plenty of knowledge and performance parts for it just across the Tasman.
The one make Suzuki Swift Sport Cup in New Zealand uses modified four-door versions of the Swift Sport, which sees them compete at every major circuit in NZ as part of the National Tier 1 Championships. The Swift is also homologated under the Super 1600 formula to compete in the Junior World Rally Championship.
It struck me as a worthwhile choice while reading how Billzilla mounted his onto a K50 box here-
http://www.billzilla.org/rcar.htm#gearbox
Edited by altezzaclub
ive dishonered the rolla name and must be shamed :(
ive only ever worked on one and don't know too much about them
Harry
Lol!
These youngsters who've only ever seen overhead cams and front-wheel drive and motors that work properly and don't drop oil and....
I remember the good ol' days!
Lol!
I have worked on engines most of my life just not toyota engines
you can't really get much more simpler than a k series
but i have worked on many single over head cam engines
mostly old Gemini's, Datsun's, and a rather oily and ancient Hit and miss engine from god knows when.
i am only 18 but i know alot more about old engines than some of the mechanics that are only trained to plug into a diagnostics port.
regards
When the Earth's magnetic fields reverse in 2012 all those non-injected motors will be the only ones running...
Except we won't have an internet to come on rollaclub and skite about it! :laff:
ok for a hceap way of doing it
5k or 7k?
so far ive seen a couple say 5k over 7k... whats peoples opinions and why?
