80ke70 Posted December 25, 2010 Report Share Posted December 25, 2010 Hey my name is James I'm 18 an from WA state an i have a newly acquired blue 1980 TE72 2 door with the quad round headlights it currently has the 3TC engine in it, Well to the point I so far have a 283 reground cam Header ported polished head/exhaust manifold/intake manifold an in the process of getting my Quad Mikuni motorcycle carbs going. Would like to avoid going with boost as things get very expensive an I am building this paycheck to paycheck an it will be my dailey driver/Honda eater. Was just wondering if someone could let me know where i should go next to get abouts 150 pony's at the wheels an have a little snort at the gas pedal when it is pushed through the floor board would like to pre-thank everyone who has something to say. Thanks, James Quote Link to comment Share on other sites More sharing options...
Redwarf Posted December 25, 2010 Report Share Posted December 25, 2010 Won't happen unless you throw big dollars at it. Quad Mikunis are no substitues for a big pair of Webers. Expect around 110 ATW. I know a well developed 3T that had 116hp. My grunter 2TG (different head, and 1600cc) had 118HP. Quote Link to comment Share on other sites More sharing options...
80ke70 Posted December 26, 2010 Author Report Share Posted December 26, 2010 You saying 110 WHP with the setup i have going? If that'll be great from the whoppin was 65-70 horses stock 3tc's have. Plus its gonna be my daily driver anyone know what Valve Springs i should use with the 283 cam? Heres a little picture of what the heads looking like so far still getting that intake manifold built for my quads. Quote Link to comment Share on other sites More sharing options...
80ke70 Posted December 26, 2010 Author Report Share Posted December 26, 2010 Need EGR port plugs on their way anyone know where i can get the water neck (only) with out all the EGR stuff. I seen the Egr cover but that just goes over the EGR holes right? Quote Link to comment Share on other sites More sharing options...
Trev Posted December 26, 2010 Report Share Posted December 26, 2010 Get a blank fitting from pirtek. Quote Link to comment Share on other sites More sharing options...
Evan G Posted December 26, 2010 Report Share Posted December 26, 2010 is that a bong in the backround? LOL!? Quote Link to comment Share on other sites More sharing options...
SLO-030 Posted December 26, 2010 Report Share Posted December 26, 2010 Looks like an old school lamp Ev. Quote Link to comment Share on other sites More sharing options...
Evan G Posted December 26, 2010 Report Share Posted December 26, 2010 beers googles don't help with my sight Quote Link to comment Share on other sites More sharing options...
Jono.C Posted December 26, 2010 Report Share Posted December 26, 2010 Could always track down a better diff ratio depending if you want it to pick up faster etc? Quote Link to comment Share on other sites More sharing options...
Redwarf Posted December 26, 2010 Report Share Posted December 26, 2010 No, I'm not saying that's what you'll have with the current set-up. As it stands now maybe a touch over 100. Maybe not. And that's with the mikunis. Although a pair of Webers would be better. Quote Link to comment Share on other sites More sharing options...
nme308 Posted December 26, 2010 Report Share Posted December 26, 2010 Hi there, The turbo thing can be done WAY cheaper than most people imagine. My daily drive has been done on a shoestring budget and shed floor scrapings. I wont post any more pics and details as I've already wasted enough bandwidth in the 'backyard turbo' thread! Burning honda's isn't an issue either! :lolcry: Cheers, Jason Quote Link to comment Share on other sites More sharing options...
80ke70 Posted December 26, 2010 Author Report Share Posted December 26, 2010 Haha no not a bong lantern deal but uhh you were saying you did your turbo setup cheap did you got efi or stay carb an i read the forum did he say the sr20 exhaust manifold fit with little fileing was confusing haha. Quote Link to comment Share on other sites More sharing options...
nme308 Posted December 27, 2010 Report Share Posted December 27, 2010 Stayed carb - 650 double pumper holley 4 barrel carb. SR20 exhaust manifold has the same port spacing and the front and rear bolts fit perfectly. The only difference is the SR manifold has 2 bolts per port and the T series shares one between 2 ports for the middle runners if that makes sense. An aftermarket top mount SR manifold would need bugger all filing/drilling to make the holes work. The standard SR manifold in factory bottom mount config fouls the T series engine mount and starter motor so I made an adapter out of 12mm steel to top mount it - about a 3 hr job with drill and die grinder plus thread tap. Cheers, Jason Quote Link to comment Share on other sites More sharing options...
