September 30, 200521 yr comment_73945 Hey I've much deliberation I've decided to get rid of the bumper bars. now, question will I have to mount the 'reflectors/illuminators(Whatever they're called)' to pass rwc? I've been told I have to apparently. Thanks Troy Report
September 30, 200521 yr comment_73954 i was told it's a no no to not run bars. apparently it's dangerous to pedestrians. as long as you don't hit any you should be right tho hey? Report
September 30, 200521 yr comment_73968 Your not planning to do this to your KE55 are you? I assume its not, as i can't think of any bumpers having reflectors? (number plate illumination lights maybe?) Report
September 30, 200521 yr Author comment_73980 Yeah I'm planning to do this to the KE55. Number plate illumination lights! They're the ones, do I have to have them? LOL, yeah I'll try stick away from pedestrians, wonder why that is? Thanks Troy Report
September 30, 200521 yr comment_74008 Yes you need to have the number plate illumination lights. Whats the reason for doing away with the bumpers? All early Corolla's look really silly without bumpers. The metalwork behind the bumper is a bit messy. Its got spot welds and two holes where the bumber brackets bolt up. If you plan to remove the front bumper, you will obviously need to make brackets to mount the indicators. Report
September 30, 200521 yr Author comment_74038 yeah I'm gonna clean the metal work behind the bumpers up. And yeah, I've got the indicators sorted. :hug: Just don't like the bumpers for some reason lol! Thanks Troy Report
October 3, 200521 yr comment_74459 just make up some brackets and bolt them to the original bumper bar spots on the rails. should be easy to do with a strap of metal Report
October 3, 200521 yr Author comment_74522 mmmmhmmmmm. That's what I'm doing. Thanks for the offer mikeys toy, are you for real? And if so, aren't you in america :D Lol Thanks Troy Edited October 3, 200521 yr by boofis Report
October 3, 200521 yr Author comment_74532 lol, isn't that a bit expensive for 2 little bumper lights? Thanks Troy Report
October 4, 200521 yr comment_74645 i dunno, they fit on either side of the plate, also if i can get enuff interest in parts, i can send one big package...i already gotta send jamie the hatch hinge and torsion bars from the te38 i will be picking up this weekend Report
October 4, 200521 yr comment_74667 Adapt some off a XF Falcon, they have them on either side of the no. plate... Or make some LED ones... (white of course...) Report
October 4, 200521 yr Author comment_74744 Na I've got the design sorted for the stock ones. Hope it's legal. Up next to the headlights, turn them sideways and attach them like that. OR if that fails, down at the bottom in the front 'panel' put some circle hole grille and mount them through that. I can't explain things well :D lol. Thanks Troy Report
October 25, 200521 yr comment_78933 This is how I mounted the front indicators/park lights. Just chopped and re welded the brackets... Report
October 26, 200521 yr comment_79248 This is how I mounted the front indicators/park lights. Just chopped and re welded the brackets... *eyes just spontaneously combusted* - OMG, what happened to it ROFL ! Report
