hey everyone just goy a stock as a rock ke55
what fuel should i use???????????????
do i have to use a valve saver fuild or not??
i had a gemini and i neva had to in them as the alloy head so would want to make sure what i should be useing in the ke55
thankz
91 octance will be fine in a stock 4K
No valve saver needed. Alloy heads have hardened valve seats from factory. Japan went unleaded back in the 70's or so i've read :hmm:
I use 95, and I'm thankful its cheap as a subsidised 10% ethanol blend! 91 would probably be OK for stock, but I skimmed the head when it was off and don't have to worry about detonation with 95.
I sat down and punched out the math once upon a time...
your car uses 10% ethanol based fuel 27% faster than 98 octane fuel and 98 does not cost 27% more. Therefore it is more economical to use 98 octane based fuel and drive efficiently than it is to use 10% ethanol blended fuel and drive efficiently.
That was based on my 04' Camry with a 2A-ZFE engine, manual transmission.
Edited by GJM85
With a carby motor just set your timing advance based on the fuel you buy. Unleaded 8-12 deg 95ron - 10-15deg 98ron - 15-20deg (depending on engine mods of course). With my old 4K I found with the timing advanced a touch as above I'd get much better fuel economy with 95 or 98 ron fuel.
i understand what your saying, but please don't use 'n' as a word. its not a word.
just chuck in 98 fuel, and wind the timing up a tad. take your car to a big hill, drive like you normally would up the hill and see if it pings. if it does, wind the timing back a bit. and try again.
note it is not unusual for a "normal" engine to ping under very heavy loading (4th gear, 2000rpm, foot to the floor, up a hill). but then again you shoudlnt be driving with you foot to the floor in 4th gear at 2000rpm. so thats ok.
in genearal:
more advanced timing = more power for the same rpm, thus you can use less accelerator to move your car, thus you use less fuel.
Edited by ke70dave
  • Upvote 1
