Millaz88 Posted May 26, 2011 Report Share Posted May 26, 2011 Got some new points and a condensor for my e7 4kc the other day to try fix up my idle and tacho troubles now got them from autobahn Points $15 or so Condensor $9 Got home and it was the wrong one so I thought Hmmmmm went back today said it's the wrong one they didn't have any others listed in there computer so I took then out n showed them the one I needed Now they found the one in the book listed for the car and bingo it was the right one but it's a huge price jump $41.99 Anyone els have this issue? I couldn't believe the price I have never seen a condensor be this expensive Before Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted May 26, 2011 Report Share Posted May 26, 2011 Ive had this issue. Constantly get the wrong one. Even if I show them the right one. I gave up. Had the same issue with getting points. Quote Link to comment Share on other sites More sharing options...
xy500 Posted May 27, 2011 Report Share Posted May 27, 2011 (edited) there is a few variants listed for the k motors, thats the problem. Without seeing the exact variant you use the parts dude will just give you the most common (cheapest) part in the hope its the right one. You really should note down the part numbers next time to save yourself the issue. Condensors are pretty much the same thing thing across 90% of points vehicles. Are you running the Denso distributor or something? Edited May 27, 2011 by xy500 Quote Link to comment Share on other sites More sharing options...
Millaz88 Posted May 27, 2011 Author Report Share Posted May 27, 2011 Nah it's a Bosch one it's the one with the thread on the mount and the bolt that goes through the vac advance bracket blots into it I have found the right one I was jast very surprised at the price difference Quote Link to comment Share on other sites More sharing options...
carbonboy Posted May 27, 2011 Report Share Posted May 27, 2011 (edited) I had an ignition module die in the dizzy of my 2AC engine. Once I diagnosed that this was the fault, I went shopping... Â Aftermarket no-frills brand price - $48, genuine Bosch price - $97. Â Bosch is pricey, but IMHO is worth it for quality bits :y: That is of course, if they give you the right bits! :wink: Â A small book that you jot down any part numbers in is a valuable tool. I use the back cover of my Haynes manual for this, very handy! :yes: I started doing this after a guy in Autobarn handed me a dizzy cap for my 4K KE70 which had 6 spark lead points & wondered why I had an issue... A 6 cylinder factory fitted engine in a Corolla?!? :hmm: I'd like to see that! :laff: Edited May 27, 2011 by carbonboy Quote Link to comment Share on other sites More sharing options...
LukeAE71 Posted May 27, 2011 Report Share Posted May 27, 2011 I had the same issue, bought a condenser for my KE20 and it was $31.00 with discount. I was shocked at the time but I guess it must be an odd one which costs quite a bit more than the others. Â It fixed my problem so I guess it was 30 bucks well spent Quote Link to comment Share on other sites More sharing options...
Millaz88 Posted May 27, 2011 Author Report Share Posted May 27, 2011 Hahaha that is always rhe way do it right ad don't go for the cheap one it always last half the time Quote Link to comment Share on other sites More sharing options...
rian Posted May 28, 2011 Report Share Posted May 28, 2011 What does a condenser actually do? I'm guessing it has something to do with the points? Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted May 28, 2011 Report Share Posted May 28, 2011 Stops interference. Same as the alt one Quote Link to comment Share on other sites More sharing options...
love ke70 Posted May 28, 2011 Report Share Posted May 28, 2011 where are you located? autobarn are cocksuckers for price jumps etc, unless its something they sell alot of they mark it up a bunch Quote Link to comment Share on other sites More sharing options...
Millaz88 Posted May 28, 2011 Author Report Share Posted May 28, 2011 I'm in hoppers crossing Found an elec dizzy I'm picking it up today then I don't have to stuff around with points again Quote Link to comment Share on other sites More sharing options...
camerondownunder88 Posted May 29, 2011 Report Share Posted May 29, 2011 HOLY CRAP $31.00 for a condenser SHIT. Â I have never paid more than 5 cents for one. Â If you keen a condenser is just a capacitor that helps prevent arcing across the points when they open making them last longer. Â Corollas are 0.22uF go to your local electronics shop capacitor worth about 5cents problem fixed. Â Or get any capacitor witha 0.22uF value and bolt it on. Â But also points and dizzy caps I find easy as to get for my K motors. I use walkers but wont touch supercrap or autobarn they are crap. The walkers I uses even has KE10 parts on the shelf ready to sell so just look for a better parts shop. Why spend your hard-earned cash at a place that rips you off gives you the wrong parts and sells shit over priced. Â As about a month ago did points dizzy cap condenser rotor button and carbie kits for the KE15. DIzzy cap was $15, points $8, rotor button $13, 2 carbie kits $60 so 30 each. They were Bosch parts or other brand names and that is what walkers charged me NO discount so aim for those pices. Â I just walk out of shops that price gouge its crap. Â Cameron Quote Link to comment Share on other sites More sharing options...
ke70dave Posted May 29, 2011 Report Share Posted May 29, 2011 What does a condenser actually do? I'm guessing it has something to do with the points? Â I'm not sure but i had mine break a few yrs back, and the car would idle fine but it would not go ANYWHERE. would just die with the slightest load applied. was weird. Â and i paid under 10bucks for mine.. Quote Link to comment Share on other sites More sharing options...
rian Posted May 29, 2011 Report Share Posted May 29, 2011 So if I have changed to an electronic dizzy, there is no reason to keep the condenser on there right? But, does that also mean there is no point in taking it off? Quote Link to comment Share on other sites More sharing options...
xy500 Posted May 29, 2011 Report Share Posted May 29, 2011 yeah u wont need one on your dist. but you should still have another on your coil. Quote Link to comment Share on other sites More sharing options...
