Motec What Is It?? Please Explain?
I'm buying a ae71 that need a motec installed on a 20valve 4age just want to know what it is and if difficult to fit?
Its a fiendish device designed to control the arcane forces that may or may not be pulsing through the static electrical haze of probabilities in the semiconductors of your ignition system...
It is sure to cause trouble and will result in endless torture for you if the imps get out.
Throw it away and fit twin DCOEs or quads!
Could you use a factory 20v ecu? Why does it "need" aftermarket engine management? Specifically a Motec unit? :hmm:
expensive also the best and i have one in my ke70 and also a haltech find out what model motec it needs
It needs a m4 i just found out it comes with the car but just needs installation ^_^ but thanks all :)
m4's are really old and outdated still better then most of the ecus out there
according to fast and the furious motec make exhausts don't they? ;)
you could just fit an Adaptronic like everyone else, proven and very cost effective
My 20v in my 86 ran a Link G4 Storm ECU. Most 20v setups will need an aftermarket ECU to allow it to control the coilpack setup etc (that is required as the distributor is usually removed).
Okidokey, makes sense. :yes:
Cheers man! :y:
uncommonrolla: when you get your car just post a heap of pictures of your engine bay and we can work out what you have
