uncommonrolla Posted July 28, 2011 Report Share Posted July 28, 2011 I'm buying a ae71 that need a motec installed on a 20valve 4age just want to know what it is and if difficult to fit? Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted July 28, 2011 Report Share Posted July 28, 2011 http://www.motec.com.au/ Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted July 28, 2011 Report Share Posted July 28, 2011 Its a fiendish device designed to control the arcane forces that may or may not be pulsing through the static electrical haze of probabilities in the semiconductors of your ignition system... It is sure to cause trouble and will result in endless torture for you if the imps get out. Throw it away and fit twin DCOEs or quads! 1 Quote Link to comment Share on other sites More sharing options...
carbonboy Posted July 28, 2011 Report Share Posted July 28, 2011 I'm buying a ae71 that need a motec installed on a 20valve 4age Could you use a factory 20v ecu? Why does it "need" aftermarket engine management? Specifically a Motec unit? :hmm: Quote Link to comment Share on other sites More sharing options...
Mitch-12 Posted July 28, 2011 Report Share Posted July 28, 2011 expensive also the best and i have one in my ke70 and also a haltech find out what model motec it needs Quote Link to comment Share on other sites More sharing options...
uncommonrolla Posted July 28, 2011 Author Report Share Posted July 28, 2011 It needs a m4 i just found out it comes with the car but just needs installation ^_^ but thanks all :) Quote Link to comment Share on other sites More sharing options...
Mitch-12 Posted July 28, 2011 Report Share Posted July 28, 2011 m4's are really old and outdated still better then most of the ecus out there Quote Link to comment Share on other sites More sharing options...
silverra23 Posted July 29, 2011 Report Share Posted July 29, 2011 according to fast and the furious motec make exhausts don't they? ;) 1 Quote Link to comment Share on other sites More sharing options...
Sam_Q Posted July 29, 2011 Report Share Posted July 29, 2011 you could just fit an Adaptronic like everyone else, proven and very cost effective Quote Link to comment Share on other sites More sharing options...
uncommonrolla Posted July 29, 2011 Author Report Share Posted July 29, 2011 Yea well il see once I get the car in my hands ^_^ Quote Link to comment Share on other sites More sharing options...
Hiro Protagonist Posted July 29, 2011 Report Share Posted July 29, 2011 according to fast and the furious motec make exhausts don't they? ;) Damnit you beat me to it... Quote Link to comment Share on other sites More sharing options...
Sloth Posted July 29, 2011 Report Share Posted July 29, 2011 Could you use a factory 20v ecu? Why does it "need" aftermarket engine management? Specifically a Motec unit? :hmm: My 20v in my 86 ran a Link G4 Storm ECU. Most 20v setups will need an aftermarket ECU to allow it to control the coilpack setup etc (that is required as the distributor is usually removed). 1 Quote Link to comment Share on other sites More sharing options...
carbonboy Posted July 29, 2011 Report Share Posted July 29, 2011 My 20v in my 86 ran a Link G4 Storm ECU. Most 20v setups will need an aftermarket ECU to allow it to control the coilpack setup etc (that is required as the distributor is usually removed). Okidokey, makes sense. :yes: Cheers man! :y: Quote Link to comment Share on other sites More sharing options...
Sam_Q Posted July 29, 2011 Report Share Posted July 29, 2011 Could you use a factory 20v ecu? Why does it "need" aftermarket engine management? Specifically a Motec unit? :hmm: you can you the factory ecu but it's not suggested: http://www.86garage.com/forums/viewtopic.php?p=10869 Quote Link to comment Share on other sites More sharing options...
Sam_Q Posted July 29, 2011 Report Share Posted July 29, 2011 uncommonrolla: when you get your car just post a heap of pictures of your engine bay and we can work out what you have Quote Link to comment Share on other sites More sharing options...
