Yn85R Hilux Carby Turbo
thats great result for small $. you have some skills!
must feel so much better to drive... when u wind the boost up you going to run a ic?
one like this you mean. it will go on when i get a chance, and will probably turn boost up to around 12psi see what it makes. wouldnt mind putting more boost into it but want to keep it reliable and at the end of the day its still slow so no point pushing it
  • Replies 32
  • Views 54.1k
  • sleepercorty
    sleepercorty
    fisinhed this last night. i guessed with the drill bit for the jet size but couldnt of got it more perfect, if you look at the dyno graph it has 12.0 afr's as flat as ive ever seen with any car. drove
  • 2 months later...
Just flogged a pic from the thread. Anything more happened with the Hilux?
I see it parked at p4cars sometimes, I have a giggle usually.
yeh the hilux is the daily most of the time, only drive the cressida a couple of times a week at the moment
135... that is epic!
i know i can barely handle to power :P , i was going to turn boost up to around 12-14psi but the top gasket of the carby just starts to leak fuel out at 9 psi so will leave it there, i changed the gasket and still does it so must be slightly uneven surfaces. i could pull carby off and machine both surfaces for a better seal but couldnt really be farked
budget also ended up at around $550 now with the intercooler and bleed valve
Looks a bit agricultural, but well thought out plan, and clearly shows with clever thinking, and experience, anything can be done,
Top work :y:
Well done! Love the advance mods!
Nothing like low-budget to make you think clever!
hows it skid?
lol it does spin the wheels but i leave the skids mainly to the cressida
Thats a fair amount of hp for a 2y hahaha, well done bud
