Might explain the lumpy as phuck idle, the slow bottom end and monster top end?
Found this:
I guess I learn how cams work tonight ;)
Edited by B.L.Z.BUB
OK so I did a bit of googling. The cams are set right, the HKS cams can run fine on standard cam gears, I will need adjustables to fine tune them perfect but for now they are ok. Checked the clearance and they seem to be within tolerances. As for the rattling noise, there are a few threads I have read with some guys who have just had rattly GTE/GZE after rebuilds when they get hot. Doesnt seem to be an issue. I'm gonna reassemble it tomorrow and take it for another drive and try and pin point the noise better.
EDIT: This is pretty much whats happening with mine. http://forum.twincam...knocking-sound/
Edited by B.L.Z.BUB
Its the sc that's noisy. Just took it for a mad boost and its gone away. Might need a rebuild. I don't care I can sit here and listen to it idle all day.
If there's a problem, yo I'll solve it...
Edited by rian
Feel free to come fix everything.
I don't know how to fix shit, I just wanted to post a picture of Vanilla Ice for the lolz
I could watch the "lumpy dumpy" vid on youtube all day!! Such an awesome idle!
Have you been freaked out by the over-run on the GZE yet? I had an ae82 GZE for today and the decel delay on the rpm when you close the throttle takes a bit to get used to.
