The Norwegian Ke70
  • Replies 63
  • Views 60.3k
It is fully driveable in this hight also :) it was 15cm drop in front and 12cm drop at the rear. Will Get the rear adapters down so it gets ET-5, than i can Get it down 1 or 2cm more :)
The police isnt happy about it, but the local police usually let it go if you not are breaking the law in other ways.. But there are also not local police that can take the plates if in the right mood..
Some more better pics
Thanks :) love the stance myself, just want it a bit more down on the rear :) just to save up to a engineswap now. Is there any easy cheap tricks to get more power before the swap itself? can't Think of any, but if there is any way..? :)
Lookin great. Love the stance too.
Good work
  • 2 months later...
Thanks guys! :)
About time to add more pics here now
I'm using the phone with a GPS speedometer because the small wheels makes the speedo show way to much. I have got info that the car is an auto that is rebuildt to manual, but still with the auto rear diff. and with theese wheels it have a mekanikal topspeed limit at 155kmH at the speedo, witch is 125kmH on GPS :P
And look what i found in the barn, from my fathers earlyer days :D
Will start the engine rebuild this summer, but it will take some time as I'm using the car as an daily in periods now :)
Looks great, now get some chrome fender mirrors and slam it on there!
Love the hoodrack too. I was searching for one locally, but no luck.
Thanks both :) don't think I will replace the mirrors, saving up all the money to engine swap instead. How much can the rear axle handle? is it just shit and will break at once, or can I use it to testdrive new engine? :)
What engine does this have? If its a 2T you'll have a T series diff which is pretty strong, plus you can get LSD for them. if its a 4k/4ac it'll probably be a Borg warner which will last a while depending on how you drive and whether you lock it ( no LSD available )
It has a 4k engine, and it is auto rear diff with 4speed manual. But don't Think it will take ti much beating.. Picking up new engine tomorow :) will be installed in the winter time, så its ready Next spring :) big rebuild coming up :)
  • 3 months later...
Long time, no see, here are some photos from sunday when i tested it on the track :)
Worked out really well, but way to litle power :P The turns impressed, and it cornered like a go-cart :)
Getting ready for the swap, only needs a gearbox to the engine, and I will start making room :)
