i have been daily driving k series corollas for 15 years now. i have had a chance to try a fair bit in that time.
of all the brands toyota is best (although you pay for it), ryco is a close second. in general, for the price of one toyota filter you can buy two rycos.
valvoline sucks, they seem to suffer bad from oil drainback. don't use them.
next you have to consider size, the normal k series filter is a Z68 (ryco number), a mid sized filter.
Redwarf runs the bigger Z9's which i have tried. i found on an older engine it can take longer to build oil pressure compared to smaller types.
also you can get the later small filter Z386 (4af/g type), these are my favourite. they are the best for instant oil pickup. they spin straight on to a k series engine.
Edited by Felix
  • Replies 44
whats the effect of using a bigger/smaller oil filter? ive heard it changes the oil pressure but wasnt sure if this was correct.
not sure (don't have an oil pressure guage). all i know is the oil pressure light goes out much faster with a smaller filter.
i like the small 4a type filters for my solid liftered 5k. ryco z386. builds pressure quicker than with larger filters. the small filters can't be too bad otherwise toyota wouldn't have used them for the 4ag series.
I know alot of the rally guys use the slightly larger filters, because the motor can take a lil bit more oil = more cooling.. etc
i didnt think that an oil filter that simply held a varger volume of oil at any time would change the pressure but slow the pressure building up and dropping away as fast. would this be right?
also, what are these "Z386 (4af/g type)" oil filters worth? and are they worth the extra compared to the standard RYCO?
we use RYCO Z37, goes straight onto the k motor & holds about 1lt, but i would buy a toyota one if it was make in japan & if they make a z37
http://www.ryco.co.nz all the info u could never need
Edited by trd
