February 5, 201214 yr comment_582294 Hey Guys, I know this may be a stupid question, but I'm curios as to whether the 4AFC and 4AFE are the same motor apart from one being EFI and the other Carby. If this is the case, does that mean that i can use a 4AFE rebuild kit on the 4AFC? I wanna keep my AE92 seca fairly standard but the km's are over 360,000km and i wanna have a spare rebuilt motor incase this one gives way. any extra info would be great :) Cheers Report
September 10, 201214 yr comment_626162 Id consider buying a 4afe to rebuild anyhow, and switch to efi when you change it over. All the parts already exist. Report
September 10, 201214 yr comment_626174 the later model 4afe (with inlet port injection), and the fc are very similar, but would go with the engine specific rebuild kit just in case. Report
October 1, 201214 yr comment_629671 I was wondering about this as well, contacted a few eBay sellers and they said the rebuild kit from the 4A-FE would not suit the 4A-FC, I don't understand why, thought it was the same engine :osama: Report
October 1, 201214 yr comment_629741 Maybe specify what is in the kit? There are little differences between the 4AFC, first gen 4AFE and 2nd gen 4AFE that could mean bits of the kit are not compatible/not required Report
October 13, 201213 yr comment_631525 I just changed my engine a week ago the tanks r the same u just need fuel Pump and lines the loom for the dash and a engine loom the heads r the same depending on the gen of the 4afe the blocks r the same different water pum Report
October 13, 201213 yr comment_631526 I just changed my engine a week ago the tanks r the same u just need fuel Pump and lines the loom for the dash and a engine loom the heads r the same depending on the gen of the 4afe the blocks r the same different water pumps and the belts r different they run the same gearboxes and engine mounts also ur exhaust is the same just minor things changed Report
October 13, 201213 yr comment_631527 If you do this this way more costly you are better off buying a complete 4afe and reconditioning it. What I did is buy a complete 1993 corolla wreaked (tail gate) then re build it and buy a engine recon kit Report
