azzy_10 Posted April 13, 2012 Report Share Posted April 13, 2012 Looking for some camber for my ke30 what have you used on your ke30-55. Whats the old camber for standard and the upgrade. Thanks. Quote Link to comment Share on other sites More sharing options...
towe001 Posted April 13, 2012 Report Share Posted April 13, 2012 I think the standard camber is about 1 deg. The lower arms from the ke2x can be used to give about 2-2.5 deg camber. the only downsides are there's no steering stops on the arms and ball joints are different. So you'll need a pair of Strut Adapter Bushings Quote Link to comment Share on other sites More sharing options...
Jono.C Posted April 13, 2012 Report Share Posted April 13, 2012 ^ My mate Michael put my ke20 arms in his ke55 and reckons it's the same. Also they're only supposed to be 10mm longer so that's about -1 degree roughly Sigma lower control arms seem to be the normal Quote Link to comment Share on other sites More sharing options...
towe001 Posted April 13, 2012 Report Share Posted April 13, 2012 I think you'll find them a little longer than 10mm Factory camber is approx 1.2-1.5 deg Also have a google on active camber and passive camber. Quote Link to comment Share on other sites More sharing options...
springersrolla Posted April 13, 2012 Report Share Posted April 13, 2012 Gh sigma I do believe, its the one without the bolt in ball joint. makes about 2.5 to 3 degrees Camber over standard, which is a little positive. Borrow a die nut from a workshop and then run it down your castor rods, around 50mm then pull your front wheels forward until they come close to the guards. My car is ʞ©$ɟin awesome handles so much nicer over stock Quote Link to comment Share on other sites More sharing options...
coln72 Posted April 14, 2012 Report Share Posted April 14, 2012 Old man cut and shut a couple of standard arms to make them longer. Can go as long as you want but need to be braced. This was for a track only car, wouldnt do it on a road car. Quote Link to comment Share on other sites More sharing options...
chestikoph1 Posted April 14, 2012 Report Share Posted April 14, 2012 not the cheapest way, but a better way of getting some more - camber. Quote Link to comment Share on other sites More sharing options...
