April 14, 201214 yr comment_597348 Hi guys, Just wanting some help in picking a engine for my ke20, I'm in nsw and wanting it to be legal. I have no set limit. Ive been told to many different things and just want hear of some conversions that have been done. Thanks Report
April 14, 201214 yr comment_597361 5k. Cheap and easy. With the advantage that it looks identical to the 3k that is already in there. Add a cam and a decent exhaust and it makes a fun combination. Report
April 14, 201214 yr Author comment_597404 Hey col, I have thought about that but I should of said I want a turbo engine. From what I can see the only legal conversion in Vic ,act and nsw is a Ca18det or similar, I'm building it for a bit of fun with my 2 sons. Spoke to a engineer and at one stage he was saying I could put a sr20det but now he is not so sure. Do you know of anyone who has a Ca18det in a Ke and what sort of power they are getting. Thanks Report
April 15, 201214 yr comment_597414 Mate there is a members rides section on this forum, have a read through and decide for yourself. 4g63 sr20 ca18 4ag 3sg As for how much power a ca18det in a ke would have, about the same as a ca18det in a silvia i would think........ Report
April 15, 201214 yr Author comment_597417 Thanks mate, Really would like the sr20 but from what I can see a lot of people have done it, but according to the laws nsw, Vic and act i read as not being legal, engineer says he believes it is possible in act . When you do the sums it comes to a 1.9 lt fi, so I'm curious to know are people getting them on the road standard and than just changing the engine. Ive seen that guy from Melbourne on here that put a Sr20 in one and just wondering if he has had it past. My brother lives in Vic so I could ergo it there if I have too. If anyone can recommend a good engineer in nsw as my one is very vague. Thanks guys Report
April 15, 201214 yr comment_597427 The set weight in QLD for a ke20 is 820kg from memory. weight x 2.5 = 2050 cc. ke25 is not so lucky with a set weight of 760kg from memory so it misses the mark. ke20 with 2 litre turbo is a legal conversion in QLD. I have seen plenty done in nsw as well. Report
April 15, 201214 yr Author comment_597564 I Really want the sr20 but just heard back from engineer and he said no way. If anyone has done it please tell me how!!!!! I have just finish paint stripping the whole car and now want to get cracking on the engine, but I want what will produce the most power I can legally put in it, don't really have a price limit just want it to have plenty of power! Report
April 15, 201214 yr Author comment_597565 And I'm planing on rebuild and working the engine I end up going with.... Report
April 16, 201214 yr comment_597789 The set weight in QLD for a ke20 is 820kg from memory. weight x 2.5 = 2050 cc. ke25 is not so lucky with a set weight of 760kg from memory so it misses the mark. ke20 with 2 litre turbo is a legal conversion in QLD. I have seen plenty done in nsw as well. Then on top of that the fact that it will be turbocharged, which from what I have 'heard' is 1.8 times the factory engine capacity, which makes it over the legal capacity for the weight of the car Report
April 16, 201214 yr Author comment_597796 According to rta web it says weight x 2.5 for forced induction So 760kg x2.5 =1900cc Which means its legal to ca18det. I brought the engine today, Report
April 16, 201214 yr comment_597832 760kg, So its a ke25...? Then on top of that the fact that it will be turbocharged, which from what I have 'heard' is 1.8 times the factory engine capacity, which makes it over the legal capacity for the weight of the car Um, no. Non turbo is weight x 3.0. turbo is weight x 2.5. Report
April 16, 201214 yr Author comment_597843 Ke20 Rta gave the weight today. Turbo engine. You multiply by 2.5 Naturally aspirated by 3 So 1.9l turbo is 100% legal With all upgrades Report
April 16, 201214 yr comment_597881 Just buy a stroker kit for the CA Not that you need to as these motors can take a pounding being an iron block Report
April 17, 201214 yr comment_597892 I'd still look at a 4agte. The last one I built for a mate just pumped out 240rwkw with plenty of scope for a fair bit more. I haven't touched cam timing yet and it will cop another 11psi(35 max). Have maxed the 38mm tial external gate at 24psi. How much power do you need in a ke20?? Stu. Report
April 17, 201214 yr Author comment_597921 Hey guys, thanks heaps for all your help, As for how much power, I want as much as I can legally get. I know it sounds stupid but now that I'm all grown up and the fact I spent My younger years doing up cars and not being able to afford the best things for my rides, now that I can afford it I don't want regret my choices, U know what mean? Report
