April 29, 201214 yr comment_600605 can anyone tell me if this is an LSD just by looking at it? pretty sure its an s series as the carrier has 8 bolt holes. I've done a burnout with this diff and it span one wheel all the way to third.. when jacked up only the wheel that is being spun will turn, the opposite side stays still. Report
April 29, 201214 yr Author comment_600611 I know this, but is this an LSD? Can you tell if it is just by looking at it? It doesn't look like any other s series I've seen before.. Report
April 29, 201214 yr comment_600618 There actually was a TRD LSD available for an S series but incredibly rare for all the reasons you can imagine. I have no idea what that is, but doesn't look like a stock S series centre? Could it be one of those tayell automotive thingies? Report
April 29, 201214 yr comment_600625 top yours, bottom my open s series center. looks the same to me. Report
April 29, 201214 yr comment_600626 "when jacked up only the wheel that is being spun will turn, the opposite side stays still" Not positive this is right, but if the motor was in gear so the tailshaft wouldnt spin, and the other wheel was in the air as well, if it was an open centre it would have had to have been spinning the opposite direction??? Sounds like maybe a stuffed l.s.d. Alos, your 'open' t series doesnt look very open now haha. Report
April 29, 201214 yr comment_600628 top yours, bottom my open s series center. looks the same to me. What a guy, goes outside, pulls out diff centre, takes photo - just for dbr11k! Report
April 29, 201214 yr comment_600629 Now i need a shower and a beer. :D Just luck its lying under my shelves rusting. Edited April 29, 201214 yr by B.L.Z.BUB Report
April 29, 201214 yr comment_600638 "I've done a burnout with this diff and it span one wheel all the way to third.. when jacked up only the wheel that is being spun will turn, the opposite side stays still." You just answered your own question, if one wheel spins its open, well if it WAS an LSD it is a shagged one. blueKsev not necessarily as with an open diff centre if both wheels are off the ground and its in gear with the engine running the so called "drive wheel" can be spinning and the other can stay still or barely turn at all. Report
April 29, 201214 yr comment_600664 if only one wheel spins it doesn't mean much, if it's in neatral even a little bit of brake drag will make it spin the tail-shaft instead of the other side. Report
April 30, 201214 yr Author comment_600719 Haha thanks guys, either way its getting the mig treatment as well :P Report
