4Age 16V Rocker Covers Won't Budge! Help
Hey guys, trying to get the rocker covers off my 4AGE, but the problem is the factory grommets/gaskets will not come off! They are extremely hard and I've tried easing a flat head underneath to pry them off but they won't budge.
Are there any suggestions? anything I could apply to help break them free?
Cheers in advance.
If you're going to be replacing the cam cover gaskets, a knife blade could be used to seperate them from the head/covers. Be careful not scratch the mating surfaces though!
It's the gaskets under the rocker cover bolts.
So I've taken all 8 bolts off but the gaskets underneath will not budge and that is what is keeping the covers on. Apparently it's pretty common, but I couldn't find any info about how to remove them because they will not move!
On my ZE, there's also a wiring loom piece that covers the rockers at the front of the motor and will stop you from getting the covers off. Otherwise, like ke70dave has mentioned, they'll need a sharp hit with a rubber mallet to break the seal.
Cheers lads, I haven't had a chance to get back to it yet! Lots going on at the moment, yep I should have my myself clear from the start, it is the washers that sit under the acorn nuts in which are giving me the problem.
I'll have a go at it with the multigrips and with the mallet.
So you guys recommend replacing them with 7AFE ones?
Also, I am thinking of getting manon racing coilovers 6/4kg soon, anybody recommend these!
Cheers.
Yes
Yes, Bazda does a good job and lots of guys on Twincam and AE82oc are running them with good results.
Edited by Hiro Protagonist
