38/38 Weber, 3/4k Hybrid Rebuild
  • Replies 56
  • Views 57.2k
I think you guys missed my point
Yes the crank diameter is different but that
is just machining.
The lump of steel used for block and heads
is basically the same with pot centres identical
in all k motors
i know what you're saying.
but if you measure up a 7k against a 5k you'll find that the blocks are different heights.
with a 7k crank in a 5k block the rods hit the bottom of the bores.
to fit the crank you'd have to machine a lot of meat out of the bottom of the bore so the rods clear, thus weakening the block too much.
felix: that sounds pretty tough :P may not be a dyno queen, but she sure would do alright in the ke15 me thinks :y:
did you ever get power figures off that?
no, never dynoed. did all my tuning with a stopwatch and later an Air/Fuel mixture meter.
i lived in Ipswich, bogan central for south east QLD. pretty much an endless supply of gung-ho meat heads out to prove the worth of the mighty falcadore to compare with. :y:
doing timing with a stopwatch. i never met the good ol' days :y:
lol
well,
got the head off today,
head is rooted..
few q's
1, what causes the valves to go white?
2, why should i use 4k rocker gear in the 3k head?
3, how do i clean up the water ports and stuff?
gunna rebuild the 4k i reckon, the 3k bigport head is going in to get a shave, inlet port match for head and weber, a 3 angle valve grind thingy.
bottom end, either rebuild, or find a 5k block!
1/4 mile time?
If your taking the head into get surface ground, they should clean the head up for you, at least that's what we do, At work we have a spraywash bin (that we manufacture as well), for all alloy stuff, cleans heads and anything alloy pretty good.
a ke30 is around 20% heavier than a ke15. normal ke15's weigh 715kg.
my old 4k (which was a late dished piston version) i got for free. it was a low kay jap import engine in perfect condition. i simply added a few reliability mods...shimmed oil pump bypass spring and double row timing chain. i shimmed valve springs to let it rev harder. let it breathe better at higher revs with minor porting, and bowl work . i had the head skimmed to up the standard compression from 9.5:1 to 9.8:1 and a 3 angle valve job. added a reground cam selected for the broadest possible power band with peak HP at around 7500 rpm.
the car had pacemaker 4 into 1's and a 1 7/8" system. i also ran a 28/36 DCD weber which provides better drivability, economy, tunability, and way more power than stock. the dizzy was a recurved bosch item.
nothing fancy, just a good overall balanced package with more time than money put into it. it gave 35mpg and was quicker than your average 6 falcadore in a light ke15.
A KE30 weighs 800 kilos, which is about 10% heavier. So if you raced with a passenger, it would be the same as having your engine in a KE30. Would it/has it, easily beaten a commodore with a passenger in with you?
Dude, what Toyota says a car weighs, and what they really weigh, are often two different things. I estimate my 55 Hardtop to be around 950 - 1000kgs. My 25 is 840kgs. A 30 ain't lighter than my 25.
my car would run 0-100kays in 8.65 seconds in testing. i worked out the speed from calculations involving tacho, tyre diameter and gearing. also driving beside new cars at night and getting the missus to check out their speedo.
yep on dozens of occasions much to the missus disgust. LOL.
really me carrying 2 passengers would be closer to the weight of a ke30 with just a driver. a ke15 is a hell of a lot smaller than a porky ke30. my old '75 ke30 2 door sedan (which are the lightest of the ke3x) had 860kgs on the rego papers which coincides with figures i have seen. jonny rochester (if he means anything to you) had his ke35(te37) weighed after a 2tg conversion and it was 950 kgs.
seriously i don't care if you can't accept how it went. fook and superjamie have been in it, when it had the 4k. ask them how they think it went....
lol.. everything has to relate to "does it beat my full sic neibours VN?"
Doug, your car hauls ass. No question about that.
