Looks like you in the same boat as me with new wheel fitment - Rears perfect and maybe a little too much offset on the front.
I was just thinking by the time a little more camber has been added the top of the front wheels would sit under the guards just nice.
Yeah as it is there is +ve camber. Might go coil overs + camber tops plus flare the fronts out a tad.
I am really happy with how they look, pity the battery is dead flat and I can't get it out of the garage for decent pics.
Its just a vinyl sticker. Can be tricky but if there is two people and you work your way from the center out its usually easy. Mine has a wrinkle in tje middle cos i worked from the outside in.
Or tape it where you want it, peel half the backing off and cut backing off and apply that half from centre out, then do other side center out, if you're by yourself. If ya get what mean.
Never been a huge fan of 4 spoke wheels, but dayum do they look good on George. Luke put the tyres on and said one was really badly buckled so I put it on the rear, took it for a quick spin and it felt fine, no wobbles or bad vibrations.
Just need to give them a polish.
