September 20, 201214 yr comment_627903 Hey all Wondering if anyone has done any hydraulic handbrake set ups. Main reason i ask is to see how it performs with drums on the rear. I can hook it up all good just don't know if its going to be worth it. Report
September 21, 201214 yr comment_627959 They work fine ,just make sure the wheel cylinders and linings are good condition. They are illegal in a road car but youre not going to do that are you. Report
September 21, 201214 yr comment_627961 They're not necessarily illegal if you have the factory cable handbrake as well. If you remove that then they're illegal. Mate got pulled over and all they wanted to see was that the original one still worked. Report
September 21, 201214 yr Author comment_627971 They work fine ,just make sure the wheel cylinders and linings are good condition. They are illegal in a road car but youre not going to do that are you. Both new so should be sweet then. yeah i was going to try to have it sitting next to the standard one as long as it will be comfortable to use. If not ill just use hydro... not going to drive it too much on the road anyway. Cheers for comments :thumbsup: Report
September 21, 201214 yr comment_628005 Go on.. put a tall vertical lever up by the dash like the WRC cars run! Frame it onto the side of the trans tunnel by your left leg. Report
September 21, 201214 yr comment_628045 Go on.. put a tall vertical lever up by the dash like the WRC cars run! Frame it onto the side of the trans tunnel by your left leg. I did this to my old ke55 rally car. worked a treat!! It will definitely be the 1st thing I put back into the rebuilt one :) Photos here : Report
September 22, 201214 yr Author comment_628167 I did this to my old ke55 rally car. worked a treat!! It will definitely be the 1st thing I put back into the rebuilt one :) Photos here : Looks alrite might be a plan. How did that activate, forwards or backwards? Report
October 3, 201213 yr Author comment_630007 Sweet got my hydro handbrake. Just need to plumb in and mount. Hey SatNav do you have any pictures of how you had yours mounted? Saw you rolled old Spike :sob: Sorry to hear that mate. Report
October 13, 201213 yr Author comment_631587 Fitted my handbrake and now normal brakes don't work hmmm. No matter what i did i couldnt get it bled started at lhr pumped like 500ml of brake fluid and kept coming out airated..... Pulled the master cylinder off gonna get it reco'd. Hoping thats it. Any other suggestions? Report
October 16, 201213 yr Author comment_632021 All good after master cylinder redone. Bled up sweet Report
