4ke70 Posted September 23, 2012 Report Posted September 23, 2012 Hey just wondering if you can double up a ke70 sway bar and if so how you would go by doing it cheers Quote
Jono.C Posted September 23, 2012 Report Posted September 23, 2012 You can run 2 rear swaybars r31s, works well. It would be do-able but you'd have to make all the mounts etc yourself Quote
B.L.Z.BUB Posted September 23, 2012 Report Posted September 23, 2012 The amount of money in fabrication to run two would more than likely exceed the amount to buy an after market bolt on one. Unless you need to double up to get around some sort of racing rules. Quote
BlueKsev Posted September 23, 2012 Report Posted September 23, 2012 Attach your second sway bar to the existing one using large hose clamps/ heaps of cable ties? Would suit a ke70 well haha But i looked into this too a while back anyway, this looks good - http://forums.turbobricks.com/showthread.php?t=9587) Quote
4ke70 Posted September 23, 2012 Author Report Posted September 23, 2012 Thanks guys what's a after market on worth?? Quote
B.L.Z.BUB Posted September 23, 2012 Report Posted September 23, 2012 Anything from nothing to $300, gotta shop around. Also depends if it the front or rear and what size you want. Why do you want one? Quote
Jono.C Posted September 23, 2012 Report Posted September 23, 2012 Go RA60 rear swaybar, 20 bucks for a wreckers, bit bigger 1 Quote
ke70dave Posted September 23, 2012 Report Posted September 23, 2012 http://www.ebay.com.au/itm/WHITELINE-18MM-ADJUSTABLE-REAR-SWAYBAR-SPRINTER-AE86-/200501954065?pt=AU_Car_Parts_Accessories&hash=item2eaed90611 contact GSL rally sport on here. I'm guessing it would be around the $230 mark going on other percentages of prices. Quote
altezzaclub Posted September 23, 2012 Report Posted September 23, 2012 Somebody on Rollaclub here had a run made of 18mm ones made. See if you can find the topic and if there are any left. Quote
