12A Bridgeport Ke10
Car: KE10
Motor & Driveline: 12abp rotary (48ida weber, gilmer drive etc..) series 5 gearbox, button clutch, shortened hilux diff
Suspension & Brakes: Rear - stock leaves for now, vl rear short stroke shocks R31 calipers, silvia discs
Front - KE10 strut bodies rear MR2 shock inserts (not yet fitted, may have to use ke20 inserts due to insert diameter), HSD coilover kit, series 5 RX7 calipers, silvia discs, whiteline 22mm swaybar
Wheels & Tyres: Front - 15x6 Superlites Rear 16x8 -4 Superlites
Interior: Factory Red
Body: Being repsprayed a metallic silver
Other: Building it for my bro RIP Nick
Started building it in may, it has been sitting around since the end of may waiting for bodywork and paint. Gonna get it sorted when I'm back in tassie next week as its sitting in the shed looking very sad. its completely stripped ready to be soda blasted inside & out. I bought a ke10 for a donor shell for all the good panels and interior. Ill also be removing the dash out of the donor and welding it into this car as its a lot nicer, must be a later model? Also will be swapping over the red interior from it into this car. Plan is to have a nice quick fun street car with a bit of poke. Just the way my little bro wanted it.
the donor car
Edited by brappin
shortened hilux diff, can't remember how long it is but its pretty short! i still have to buy a good center and gears for it, but theres a lot of different centers online from the u.s and i don't want to buy the wrong one. the wheels fill the gaurds nicely, but theres not much room between the leaf hanger on the diff and the rim.
Edited by brappin
I quite like it in its current guise,
Did you use a rotary crossmember or on the ke member?
And doing it for the bro, something about them makes them more unique
You know I'm keen to see this done Reegan!
Edited by Jono.C
used the rotary mount and made a new crossmember that bolts in between the rails. i havent got many good photos of it. the ke crossmember is all cleaned up so theres nothing un neccessary hanging off it.
i can't wait to finish it and cruise around poppin cherrys
Any idea what your offset is? And if you would be so kind to measure track, I'll work out the rest. Are you expecting a lot of scrubbing or is it pretty clear to the guard lip.
Love it. 16 by 8 is massive but I do enjoy the way it fills it out!
nah i can't remember what they are & I'm 6000kms away from home till xmas. its got a pretty tough stance for the way its looking atm
this looks pretty sweet mate. Will be keeping an eye on this one ;)
Says the man that hates rotaries :P
  • 4 weeks later...
change of plans, selling the 12a setup and dropping a new series 6 extend port 13bt in. maybe even a simple half cage too. fun!
  • 7 months later...
I’ve started working on this again. I got the Hilux diff under it last week. Cut out the old dash and welded in the one out of the parts car. There’s a couple of difference between the years but it fits with some small modifications. It’s only metal!
Next on the to do list is mounts for the R31 rear calipers, run new brake and fuel lines, pull out the crossmember and clean up all the old engine mounts.
Dash in
Diff in
Good work mate, keep this build up. Great to see another 10 being built, I'm sure your brother would be super stoked.
Great idea man wicked memorial build keen to see this rotary brappin. This is a great way to remember your brother.
