gt500biatch Posted January 17, 2013 Author Report Share Posted January 17, 2013 i had a spare relay i tried that, still nothing :( i followed the wiring there doesnt seem to be anything wrong :( and when the fuel pump primes the relay makes a noise (its always done it). also checked the ecu doesnt seem like there is any leeks .... this is a bummer :( Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted January 17, 2013 Report Share Posted January 17, 2013 I wonder if the 'Start yeah Bastard solution" was a false result, it would have started without the can anyway.. That's the one test that pointed to the fuel side being the problem. How do you get it to start when it has refused to?? Will it crank a dozen times with no hope, then suddenly start on the 13th, or is it after you fiddle with something? Having it reliably not-start is just as important for working out why it won't. Quote Link to comment Share on other sites More sharing options...
gt500biatch Posted January 17, 2013 Author Report Share Posted January 17, 2013 it can't be spark coz i checked the coilpacks they tick, new sparks. also iv used start your bastard more than once to be sure it is fuel and everytime i spray into the itb's it starts then dies once the ero spray is finished. and last time i cleaned the fuel rail and fiddled with the ecu wiring and relay and it started, and i drove it for a week..... its deffs a fuel issue :/ new pumps they prime etc but yeh I'm lost :( Quote Link to comment Share on other sites More sharing options...
It's_AUDM_Yo Posted January 17, 2013 Report Share Posted January 17, 2013 Have you tried taking the fuel line of before and after the rail to see if fuel pisses out when you crank it? Quote Link to comment Share on other sites More sharing options...
gt500biatch Posted January 17, 2013 Author Report Share Posted January 17, 2013 yeh it does the in line bbut the out only dripps :/ Quote Link to comment Share on other sites More sharing options...
gt500biatch Posted January 17, 2013 Author Report Share Posted January 17, 2013 the injectors were cleaned and tested nothing wrong there unless its a wiring issue :/ but I'm no sparky so i can't really tell :( haha Quote Link to comment Share on other sites More sharing options...
gt500biatch Posted January 17, 2013 Author Report Share Posted January 17, 2013 replaced the 12v relay still nothing :( Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted January 17, 2013 Report Share Posted January 17, 2013 Once it starts it does run fine?? I assume there is a cold-start part of the ECU program, separate from the warm-running program. Is there hardware associated with that?? Some enrichment device or air bleed that might not be working correctly. Quote Link to comment Share on other sites More sharing options...
ke70dave Posted January 17, 2013 Report Share Posted January 17, 2013 (edited) This car is such a custom made thing that we can only take stabs in the dark. I would get inside that ecu, and see what is happening when it wont start. If the wiring is anything like i sold it, pretty much all of it needed to be replaced! Edited January 17, 2013 by ke70dave Quote Link to comment Share on other sites More sharing options...
gt500biatch Posted January 17, 2013 Author Report Share Posted January 17, 2013 it doesnt start at all :( Quote Link to comment Share on other sites More sharing options...
gt500biatch Posted January 17, 2013 Author Report Share Posted January 17, 2013 Dave its a new wiring loom coz its a different motor i don't think it has anything to do with the chassis wiring, more the engine harness. but I'm totes puzzled :( Quote Link to comment Share on other sites More sharing options...
gt500biatch Posted January 17, 2013 Author Report Share Posted January 17, 2013 update, took the sparks out they are dry as fk :( so defs not getting fuel, the rail gets fuel but its not getting through. borrowing a mates multimeter to check the injector plugs this evening ! Quote Link to comment Share on other sites More sharing options...
It's_AUDM_Yo Posted January 17, 2013 Report Share Posted January 17, 2013 (edited) I'd try and find a fuel rail you can borrow or buy cheaply and swap it over. That really doesn't sound right, It could have a major clog or corrosion. Edited January 17, 2013 by It's_AUDM_Yo Quote Link to comment Share on other sites More sharing options...
gt500biatch Posted January 17, 2013 Author Report Share Posted January 17, 2013 i don't think it is the rail coz i pulled out the hose on the other end and fuel pisses out :( Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted January 17, 2013 Report Share Posted January 17, 2013 Get an LED bulb if you can, use it to test if your injectors are pulsing. Normal bulbs wont flash fast enough. Quote Link to comment Share on other sites More sharing options...
