January 7, 201313 yr comment_642775 Hey everybody, Greetings from Portland, Oregon! I'm a new member of the forum and wanted to get the ball rolling by posing this question; I noticed so many of you have KE corollas, and it seems that the TE is less common on the forum. Thoughts, opinions? Report
January 7, 201313 yr comment_642779 Hello Evan I assume I'd be right in saying this is a predominately Aussie members site. In Aus we just flat out barely got any Te model cars. Don't know if the T series engines had issues with regs here or something but there is just none around here. Report
January 7, 201313 yr comment_642783 I think the only T engine we got was the 3t in the t18? And there arent many of them compared to how many K motors we got. what are your experiences brownevan? Report
January 8, 201313 yr comment_642792 T>K in stock form. K has a special place in our hearts though. What it loses in power and technology, it gains in reliability. Report
January 8, 201313 yr comment_642796 What diff does the TE have?? Borgwarner or Jap banjo?? Most of the variants depended on local availability and local assembly in bigger countries. Usually I reckon America got large and lazy motors, Australia got small and lazy motors, and Japan used all the really good gear we love. If countries were just inmporting cars from Japan they got the good stuff, like NZ after it dropped local assembly, but if there was a local factory you got what was being made locally. I assume Aussie got 4K, K40 and K50 boxes on BorgeWarner diffs, while the USA was getting 3T with T gearboxes and banjo diffs. Report
January 8, 201313 yr Author comment_642805 from "The 71-74 corolla website" TE and KE models: KE models have smaller front brakes and no brake booster. Battery tray on the right front corner. TE models have 9" disc brakes, brake booster and battery tray on the left front corner. TE came with a 2TC (Trueno models a 2TG), and KE models came with a 3KC. KE models had a manual choke as well, whereas the TE models had a "heat riser" choke (air is heated through a tube running through the exhaust manifold, which heats a spring attached to the stock carb, which opens the choke when hot). KE and TE engine mounts are different http://www.pgrramblers.org/corolla/index.cfm?ContentID=117 Report
January 8, 201313 yr comment_642821 I can't see why none where brought in by Toyota to Australia the celicas had T engines so I can't have seen any problems with them bringing them in, probably just no market for them when they were being made. The TE's had the T series Banjo diffs, T engines and whatnot. I never had any problems with my 3T in regards to reliability and it copped nearly 9k rpm with just a 38/38 weber and an exhaust, only problem I ever had was the dipstick popping out sue to so much pressure when revving to said 9k rpm, so just used an extension spring to keep it put, only reached those rpms on downshift, but was very reliable and a lot of fun, would be even more fun in a lighter chassis like a ke1x/2x I would love to build a 200ish hp 3tc to put in one. Report
January 8, 201313 yr comment_642824 We still only get "sensible" autos here because our government is, and always has been, a bunch of cock washers. Report
January 12, 201313 yr Author comment_643336 Haha, so I guess the question I really was curious about was the 3K vs 2TC...... any thoughts? Report
January 12, 201313 yr comment_643360 I'd take the 2tc any day. You get way better out comes as far as tuning goes. Report
January 12, 201313 yr comment_643385 The 2TC will blitz a 4K anytime. Its 1600cc compared to 1300, cross-flow head compared to same-side manifolds, it has a hemispherical combustion chamber I assume, compared to a bathtub, and the race versions made 180bhp, while no-one who was sane ever raced a 4K! We would all love for KEs to have come out with T motors instead of Ks! The K is definately 1950s technology, the T is 1970s. Report
January 12, 201313 yr Author comment_643398 I would have loved my KP to have come with a 2TC.... the 4k that's in it has a cam, full 2in all the way back, full top end rebuild, and its zippy up above 3k, but the stock 2tc motor puts the 4k to shame in the low rpm range. I need to have my distributor recurved i think.... my 4k below 3000 is LAGGY, but its quick from 3-6000... I was just curious; I was like "how does this stock 2tc feel so good?" Report
January 13, 201313 yr comment_643438 Grab a timing light and generate an advance curve, then compare it to the work I did on the 5K dizzy in the build in my signature. You can see the curve mine handles happily on 95octane. If your getting to 2000rpm with less than 25deg advance you can improve it. What carb are you using? Giant throats & ports will make the bottom end hard to work. Report
January 19, 201313 yr comment_644311 I have a stock 2tc in mine, and I love it even with a tri-matic. And for the reliablility, my parents had a te70 with a 3tc in it. The car got up into the 360k mile range before it was retired with the original engine, t50 trans, axle, etc... It still ran after we parked it. Edited January 19, 201313 yr by Skellington Report
January 19, 201313 yr comment_644335 My other T18 I just sold had 380xxx on it and still ran very well. Report
