February 24, 200620 yr comment_103921 The 3K engine has a few different codes. What do they mean? 3K 3K-D 3K-B 3K-H 3K-C As Pauline Hanson said "Please Explain" Edited February 27, 200620 yr by AE35 Report
February 24, 200620 yr comment_103931 the only one i know off the top of my head is c means it conforms to the californian emmision standards which are one of the highest standards in the world h i have no idea about same for the others cheers other than its the 3 rd gen in the k family Report
February 24, 200620 yr comment_103938 does this help at all? Toyota engine codes are split into two sections, the bit before the dash, and the bit after it (eg: 2JZ-GTE). Before the dash. The letters signify the "family" or "series" of the engine. The numbers signify a revision of the bottom end (ie: bore, stoke, block). Higher numbers don't necessarily mean a larger block. For example, the twin turbo engines in modern Supras are the 1JZ-GTE and 2JZ-GTE. The 1JZ is a 2.5L engine, while the 2JZ is a 3.0L. Both are twin turbo inline sixes. After the dash. The letters after the dash specify the features of the engine. G - Wide angle Twin Cam (sportier head) F - Narrow angle Twin Cam (economical head) T - Turbocharged Z - Supercharged E - Electronic Fuel Injection U - Emissions control (Japanese) C - Emissions control (Californian). Sample Engines And Their Codes These are a few engines that can be found in our members' cars. 4A-GE: 1.6L DOHC EFI 16V inline four cylinder 4A-GE (20 Valve): 1.6L DOHC EFI 20V inline four cylinder 4A-GZE: 1.6L DOHC EFI 16V supercharged inline four cylinder 7A-FE: 1.8L DOHC EFI 16V inline four cylinder 1G-GTE: 2.0L DOHC EFI 24V intercooled twin turbo inline six cylinder 3/4K-C: 1.3L OHV Carby 8V inline four cylinder (4K block, 3K head) 5M-E: 2.8L SOHC EFI 12V inline six cylinder 7M-GTE: 3.0L DOHC EFI 24V turbocharged inline six cylinder 18R-C: 2.0L SOHC Carby 8V inline four cylinder 18R-GEU: 2.0L DOHC EFI 8V inline four cylinder 3S-GE / 3S-FE: 2.0L DOHC EFI 16V inline four cylinder 3S-GTE: 2.0L DOHC EFI 16V turbocharged inline four cylinder 2T-G: 1.6L DOHC 8V inline four cylinder Report
February 24, 200620 yr comment_103960 What does U stand for, I've searched for this before but to no avail. Report
February 24, 200620 yr Author comment_103962 Its written above. U = Jap Emission Control Standards Report
February 24, 200620 yr comment_103972 Shit, how the hell I missed that I don't know... thnaks mate. Report
February 25, 200620 yr comment_104118 i beleive H was also a 'sportier' version.. different porting on heads and no emissions crap :locked: Report
February 27, 200620 yr comment_104592 Mine is a 3k-h, dunno if its a sporty variant or not, but its pretty fit for a k motor: it'll chirp first.lol. Report
February 27, 200620 yr Author comment_104660 I got a 3K-H in the panel van and it hauls pretty well. Especially once i adjusted the vacuum advance on my nippon-denso distributor! The knob on the left is to advance the timing. :jamie: Who else has this style of distributor? They came out in KE20, 25 & 26 models. Edited February 27, 200620 yr by AE35 Report
February 27, 200620 yr comment_104712 The knob on the left is to advance the timing. :jamie: Who else has this style of distributor? They came out in KE20, 25 & 26 models. Actually it's a octane selector and it's a not the best place to adjust your timing, because it allso restricts your vacuum advance actuators movement. Found in older K-engines. 3K-H is an older bigport engine, ours were pre -75 ones. 3K-B is obviously twin carbie Report
